Error with Zigbee
Posted: Thursday 15 October 2020 11:51
by EdwinK
As I'm relatively new with Zigbee I'm running into an error I can't find how to fix. Everything seems to be working without a problem thoug.
2020-10-15 07:38:37.185 Error: (deCONZ) Can't Update Unit > 65520 (groups) : {'nValue': 1, 'sValue': 'on'}
When I look at this, to me it says that there are more then 65520 groups? I only have added a group living room, bedroom, ambiance and ceiling-lights. That is three.
Re: Error with Zigbee
Posted: Thursday 15 October 2020 17:27
by Thorgal789
Hello.
No, don't worry, it s the group id, this one is the invisible group used by the gateway, is a group will all your lights (used by phoscon, useless for domoticz)
The normal procedure is an error at start (because this group is invisible, so domoticz can't see it during synchronisation
2020-10-15 17:23:12.031 Error: (deCONZ) Websocket error, unknow device > 65520 (groups)
After that domoticz ask for information and add this group to domoticz, and avoid all new error message.
I think you have disabled the "new device addition" option in domoticz, so the plugin can't add it ?
Posted: Friday 16 October 2020 8:51
by EdwinK
Yes. I have the 'new device' disabled, as I don't want to get 100's of devices from neighbours.
Will see what happens when I turn it on.
Posted: Friday 16 October 2020 12:55
by Dave21w
You won't get any neighbours devices, a zigbee device has to be in pairing mode to be able to be seen by a coordinator, I have a running system and a test system, neither see's the devices on the other setup.
Posted: Friday 16 October 2020 16:45
by Thorgal789
And if you want to avoid some device, you can add them in the banned.txt file, they will be inored by the plugin.
Posted: Friday 16 October 2020 17:16
by EdwinK
What I meant were devices that RFXcom would pick up because of the 'allowance of hardware' in settings.
Posted: Friday 16 October 2020 18:36
by Dave21w
Good point !
Posted: Tuesday 27 October 2020 22:09
by EdwinK
So, now that I have it the 'device activation' on for some time, I just noticed it created over 100 new devices. That was not something i wanted. So, I turned it off, and removed all those unwanted devices. Now the websocket error is back again,
Posted: Wednesday 28 October 2020 17:06
by Thorgal789
You just need to have the device created by the plugin called "deCONZ - Group 65520" ID = "GROUP_Group_65520", after that you can re disable the "device activation".
