Lux value only updated after motion is detected <solved>  [Solved]
nitpicker
Domoticz version: 2022.2
Post by nitpicker »
I've a Aqara motion sensor that also shows the amount of lux. I want only execute an action when there is motion when the amount of lux is lower then a certain value. The problem is, the lux is only updated as soon as it detects motion... How can I execute the script once the lux value is updated and motion is triggered?
return
    on =
        devices = {
            'MS','MSL'
        if ((device.name == 'MS' and device.active) and (device.name == 'MSL' and device.lux < 10 )) then
            domoticz.notify('Motion', 'Motion triggered', domoticz.PRIORITY_EMERGENCY)
I tried the above solution, but that didn't work, of course...
Last edited by nitpicker on Wednesday 14 October 2020 15:18, edited 1 time in total.
Re: Lux value only updated after motion is detected
nitpicker wrote: Wednesday 14 October 2020 8:51 I want only execute an action when there is motion when the amount of lux is lower then a certain value.
Could look like below,
It might send the notification twice. Then change 'MS','MSL', to 'MS' ,
return
    on =
        devices =
            'MS','MSL',
    logging =
        level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when all runs ok
        marker = 'lux on motion',
    execute = function(dz)
        local motionSensor = dz.devices('MS')
        local luxSensor = dz.devices('MSL')
        if motionSensor.active and ( luxSensor.lux < 10 ) then
            dz.notify('Motion', 'Motion triggered', dz.PRIORITY_EMERGENCY)
nitpicker
Re: Lux value only updated after motion is detected  [Solved]
Post by nitpicker »
Now it works as intended! It sends two notifications, but I will change it to MS only.
Thanks again!
