Electricity data not passed to Virtual Sensor by Node-RED
mash47
Domoticz version: v4.10717
Post by mash47 »
I'm trying to show data in a virtual Electric(Instant+Counter) sensor. The data is pulled in via MQTT from a remote server and the Node-RED output in the debug screen is ...
11/10/2020, 20:25:35 node: 873abf91.f3419
SMART/HILD/************ : msg.payload : Object
{ command: "udevice", idx: 89, nvalue: 0, svalue: "511;13700450" }
However the data does not reach the sensor.
If I use this JSON command
http://192.168.178.41:8080/json.htm?type=command&param=udevice&idx=89&nvalue=0&svalue=123;456789000
the sensor shows the data.
I've even tried using a TEXT 'sensor' to show the current time by using this example at ...
https://www.domoticz.com/wiki/Flows#Sen ... example.29
provided by MinderGas and this doesn't work either.
Any debug suggestions would be greatly appreciated.
mash47
Re: Electricity data not passed to Virtual Sensor by Node-RED
Post by mash47 »
***************** FIXED *****************
In the 'MQTT Client Gateway with LAN interface' Remote Address field I'd entered the remote server info instead of localhost.
