help I want to make the sum of two values Topic is solved
smaus
Post by smaus »
Is there someone who can help me to make a script ( i don't have any idea how to do that ).
I want to make the sum of two values from my enphase 8.302kwh-5629kwh=2673kwh
the idx enphase1 = 5291
The idx enphase2 = 5293
thank you in advance
Re: help I want to make the sum of two values
smaus wrote: Sunday 11 October 2020 16:03 Is there someone who can help me to make a script ( i don't have any idea how to do that ).
Could look like below as dzVents script
___________________________________________________________________________________________________________________________
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
return
    on =
        devices =
            'Enphase1',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Delta Enphase1 and 2',
    execute = function(dz, item)
        targetDevice = dz.devices('powerDelta') -- define as virtual custom sensor
        local enphase1Today = item.counterToday
        local enphase2Today = dz.devices('Enphase2').counterToday
        local delta = enphase1Today - enphase2Today
        dz.log('Delta of enphase1 en enphase2 counterToday: ' .. delta, dz.LOG_DEBUG)
        targetDevice.updateCustomSensor(delta)
nico4sen
Post by nico4sen »
I did it with a room plan and a PHP script. There is somewhere a topic about adding two values.
Update: https://r.tapatalk.com/shareLink/topic? ... source=app
smaus
Post by smaus »
waaren wrote: Sunday 11 October 2020 22:26
the script works, absolutely great.
Thank you very much for the effort
smaus
Post by smaus »
nico4sen wrote: Monday 12 October 2020 19:37 I did it with a room plan and a PHP script. There is somewhere a topic about adding two values.
Thanks for the link.
