Version: 2020.2
Platform: Raspberry pi 3b + Rasbian (debian Buster)
Plugin/Hardware: RFXtrx433E HW 1.2
Description
I'm trying to get this switch none in domoticz.
https://www.aliexpress.com/item/3301140 ... 4c4d7CMfsR
it sends directly a signal at power up.
The purpose is to place this over the door Bel (with a bridge rectifier)
With RFXmanager i see the signal at powerup of the switch.
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 56
Code = 112FA4 decimal:1126308
S1- S24 = 0001 0001 0010 1111 1010 0100
Pulse = 336 usec
Signal level = 7 -64dBm
I tried to add the switch to domoticz, (allow new hardware/sensors), learn on the switch tab, manual add switch with different types etc, without any result.
I checked the forum and web, not founding an answer. But may some readers had the same idea and has it working or some tips to try is also good.
Thanks in advanced
Add special switch in domotics (doorbell function)
Rutger
- Domoticz version: 3.5135
Raspberry pi 3B
Domoticz Version: 2020.2 b63341bc0 dzVents Version: 3.0.2 Python Version: 3.7.3
RFXcom RFXtrx433E HW 1.2
