Dashticz won't show lacrosse tx3 type temp reading while domoticz does.
Posted: Saturday 03 October 2020 14:08
by Douwe
I can't get Dashticz to show the temp reading of the inverter.
In domoticz I get a correct reading of 32° C.
In dashticz the block remains empty and the following blocks in the column are not shown anymore.
Also the page sliding didn't work anymore and the second page is displayed under the first page. So with scrolling down you get the second page.
I use the latest beta.
https://192.168.xxx.xxx/json.htm?type=devices&plan=0&filter=all&used=true&order=Name
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "LaCrosse TX3",
"Temp" : 32.0,
"Timers" : "false",
"Type" : "Temp",
"TypeImg" : "temperature",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "352",
"trend" : 2
blocks['352'] = {
 title: 'Temp Omvormer',
 width: 4
Any ideas?
Re: Dashticz won't show lacrosse tx3 type temp reading while domoticz does.
Posted: Saturday 03 October 2020 14:38
by Lokonli
Did you already try with
config['use_favorites'] = false;
Posted: Saturday 03 October 2020 14:56
by Douwe
Lokonli wrote: Saturday 03 October 2020 14:38 Did you already try with
Thanks for helping me!
But that didn't change it.
Posted: Saturday 03 October 2020 15:09
by Lokonli
Open DevTools in Chrome by pressing F12. Refresh Dashticz.
Which error is reported in DevTools console tab?
Posted: Saturday 03 October 2020 16:02
by Douwe
Lokonli wrote: Saturday 03 October 2020 15:09 Open DevTools in Chrome by pressing F12. Refresh Dashticz.
Hope this is what you asked:
TypeError: deviceValue is undefined
    getStatusBlock js/blocks.js:783
    createBlocks js/blocks.js:1945
    createBlocks js/blocks.js:1908
    getBlockTypesBlock js/blocktypes.js:314
    handleDevice js/blocks.js:1293
    deviceUpdateHandler js/blocks.js:174
    addDeviceUpdateHandler js/blocks.js:226
    subscribe js/domoticz-api.js:533
    subscribe js/domoticz-api.js:454
    addDeviceUpdateHandler js/blocks.js:224
    getBlock js/blocks.js:82
    buildScreens js/main.js:619
    onLoad js/main.js:345
    loadFiles js/main.js:295
    mightThrow http://192.168.178.116:8082/dist/bundle.js?t=5:305
    F http://192.168.178.116:8082/dist/bundle.js?t=5:305
js/main.js:299:15
XML-parsefout: ongedefinieerde entiteit
Locatie: http://192.168.178.116:8082/tpl/graph_header.tpl
Regelnummer 5, kolom 65: graph_header.tpl:5:65
Uncaught TypeError: deviceValue is undefined
    set js/domoticz-api.js:561
    set js/domoticz-api.js:560
    setOnChange js/domoticz-api.js:348
    _setAllDevices js/domoticz-api.js:371
    onmessage js/domoticz-api.js:207
line 294 > injectedScript:783:28
XML-parsefout: troep na documentelement
Locatie: http://192.168.178.116:8082/tpl/graph_tooltip.tpl
Regelnummer 16, kolom 1: graph_tooltip.tpl:16:1
    forEach self-hosted:206
Posted: Saturday 03 October 2020 16:45
by Lokonli
There are indeed some errors reported. Now we have to find out what's causing this.
It seems there are at least two errors: one in a graph header, and one with a Domoticz block.
It can be caused by Domoticz block id 352, but it can also be something else.
First, can you remove domoticz id 352 from the column definition, and also the graphs that are using device 352?
Refresh Dashticz and check again whether the DevTools console is error free.
If there are still errors reported without device 352 we take the next step in debugging.
Posted: Sunday 04 October 2020 13:01
by Douwe
Thanks for your help Lokonli! very much appreciated.
When I remove IDX 352 form the column I get the following warning (but no errors):
DevTools failed to load SourceMap: Could not load content for http://192.168.178.116:8082/ical.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
The page sliding is working again.
(there was no graph for 352 added to CONFIG.js)
Posted: Sunday 04 October 2020 15:42
by Lokonli
ok, then the problem is indeed related to device 352.
What is your exact Dashticz version? If it's lower than 3.6 please switch to 3.6 master (or latest beta) first.
If your custom.js is not empty, can you post it here?
Do you have a block definition for device 352 in CONFIG.js? If yes, can you post that part here?
On what kind of system did you install Dashticz? (windows, Ubuntu, Pi, Synology)
Domoticz is on the same system?
Can you post the complete Domoticz json output for device 352:
http://192.168.178.116:8082/json.htm?type=devices&rid=352
Posted: Monday 05 October 2020 18:37
by Douwe
Hi Lokonli,
Again, your help is very much appreciated!
I am on a Pi 2 b (with buster)
domoticz is on the same system.
custom.js:
pi@raspDomo:~/dev/dashticz/custom $ more custom.js
 //add custom javascript in here
function afterGetDevices(){
if (Domoticz.getAllDevices()[s2].Data == 'Off') {
$('.block_S2 .title').addClass('warningblue');
$('.block_S2 .state').addClass('warningblue');
else {
$('.block_s2 .title').removeClass('warningblue');
$('.block_s2 .state').removeClass('warningblue');
function getExtendedBlockTypes(blocktypes){
        //blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
        return blocktypes;
version:
pi@raspDomo:~/dev/dashticz $ more version.txt
"version": "3.6.3",
"branch": "beta",
"last_changes": "More dials",
"changelog" : {
            "3.6.2": "Fix for graph issues in 3.6",
            "3.6.1": "Custom HTML block",
            "3.6.0": "Beta version derived from 3.6 master",
            "3.6": "Master version"
CONFIG.js:
blocks['352'] = {
 width: 4
Your url:
gave a '404' result (page not found)
http://192.168.178.116:8080/json.htm?type=devices&plan=0&filter=all&used=true&order=Name
copied the 352 part
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "32.0 C",
			"Description" : "",
			"Favorite" : 1,
			"HardwareID" : 17,
			"HardwareName" : "PVOUtput",
			"HardwareType" : "PVOutput (Input)",
			"HardwareTypeVal" : 30,
			"HaveTimeout" : false,
			"ID" : "0001",
			"LastUpdate" : "2020-10-05 18:20:22",
			"Name" : "Temperatuur Omvormer",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Temp" : 32.0,
			"Timers" : "false",
			"Type" : "Temp",
			"Unit" : 1,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "352",
			"trend" : 2
Posted: Monday 05 October 2020 19:00
by Lokonli
I see the HardwareType is 'PVOutput (Input)'
A specific blocktype is defined for this kind of hardware, but I see in the code that the assumption is that it's an energy device, not a temperature.
Do you also use other PVOutput devices?
As a quick hack, can you try with the following in custom.js (the function getExtendedBlockType is changed):
(other PVOutput devices will not work anymore!)
else {
        blocktypes.HardwareType['PVOutput (Input)'] = {
          icon: 'fas fa-thermometer-half',
	  title: '<Name>',
  	value: '<Temp>' + _TEMP_SYMBOL,
  	format: true,
  	decimals: 1,
        return blocktypes;
If this solves the issue with the temperature device, I'll think of a real fix.
Posted: Monday 05 October 2020 19:58
by Lokonli
Can you post the Domoticz json output of all your PVOutput devices?
Posted: Monday 05 October 2020 23:07
by Douwe
Lokonli wrote: Monday 05 October 2020 19:00 I see the HardwareType is 'PVOutput (Input)'
else {
	  title: '<Name>',
  	format: true,
  	decimals: 1,
        return blocktypes;
I changed custom.js with the code you wrote. The result is that the block 352 is displayed correctly.
However, as you remarked, is the rest of the blocks coming from PVOutput(input) disappeared and after block 352 is the rest of the page/column empty.
Here the other PVPOutput(input) data:
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CounterToday" : "6.000 kWh",
			"CustomImage" : 0,
			"Data" : "25289.600 kWh",
			"Description" : "",
			"EnergyMeterMode" : "0",
			"Favorite" : 1,
			"HardwareID" : 17,
			"ID" : "00000001",
			"LastUpdate" : "2020-10-05 22:45:23",
			"Name" : "SolarMain",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"SubType" : "kWh",
			"SwitchTypeVal" : 4,
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "current",
			"Unit" : 1,
			"Usage" : "0 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "353"
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"CounterToday" : "37.480 kWh",
			"CustomImage" : 0,
			"Data" : "63236.488 kWh",
			"Description" : "",
			"EnergyMeterMode" : "",
			"Favorite" : 1,
			"HardwareID" : 17,
			"ID" : "00000002",
			"Name" : "SolarConsumed",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"SubType" : "kWh",
			"SwitchTypeVal" : 0,
			"Timers" : "false",
			"Type" : "General",
			"Unit" : 1,
			"Usage" : "1337 Watt",
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "354"
For 'SolarMain' (IDX 353) and 'SolarConsumed' (IDX 354) a total of 6 blocks are generated. For me at the moment not totally clear, what the values displayed are saying.
So the solution you suggested is not a total fix for the problem.
Posted: Tuesday 06 October 2020 9:18
by Lokonli
Douwe wrote: Monday 05 October 2020 23:07 For 'SolarMain' (IDX 353) and 'SolarConsumed' (IDX 354) a total of 6 blocks are generated. For me at the moment not totally clear, what the values displayed are saying.
Should be fixed in latest beta. Can you test?
You have to reverse you changes to the getExtendedBlockTypes function in custom.js:
        return blocktypes;
The PVOutput energy devices will create three blocks: Total Energy, Energy today, Actual power.
If you only want to show the actual power, you have to use '353_3' and '354_3' as device ids.
Re: Dashticz won't show lacrosse tx3 type temp reading while domoticz does. [SOLVED]
Posted: Tuesday 06 October 2020 11:22
by Douwe
Hi Lokonli,
Thanks for your help. After the update the PVOutput temp block works fine and also the other PVOutput blocks were displayed.
For your information I added a jpg with the PVOutput devices.
So I think this is solved!
Posted: Tuesday 06 October 2020 17:13
by Lokonli
Great! Thanks for the feedback :)
