[SOLVED] EvoHome devices not showing since 3.4.6
Posted: Wednesday 30 September 2020 12:00
by wimmme
I have my Evohome available in Domoticz via the web API. Working great until 3.4.5. In 3.4.5 they still show, any version after that doesn't show them.
Not the Heating zones, not the controller. Not in regular shape, not as a dial.
I tried a lot ! Clear cache, reboots, beta and master branches, total new config, starting from scratch, removing and adding devices again ...
Anyone has got their EvoHome working in dashticz in any version after 3.4.5, master or beta branch ?
Thanks in advance
Re: EvoHome devices not showing since 3.4.6
Posted: Wednesday 30 September 2020 12:10
by Lokonli
wimmme wrote: Wednesday 30 September 2020 12:00
Thanks in advance
I have it working ...
Did you set use_favorites to false in CONFIG.js?
Posted: Wednesday 30 September 2020 12:45
by wimmme
Lokonli wrote: Wednesday 30 September 2020 12:10
it was on 0, tried with 0,1,false, true, removing, ...
it does show a block when using dial but nothing in it, just the title
Posted: Wednesday 30 September 2020 13:31
by Lokonli
Then we have to do some more debugging ...
(1)
In Chrome, can you open DevTools (F12), refresh Dashticz, and then post here the errors and messages in the Devtools console tab?
(2)
Can you post the output of:
http://<domoticz ip:port>/json.htm?type=devices&rid=123
replace 123 by the Domoticz device ID of your evehome devices.
Posted: Wednesday 30 September 2020 15:32
by wimmme
Lokonli wrote: Wednesday 30 September 2020 13:31
(1)
(2)
Hmm, you got me on the way.
At first it was php not found. Could be correct since i am hosting it on Windows in IIS.
That might be a thing, don't know IIS wasn't supported.
Fixed it by installing Php in IIS. I use 7.4.1 now, confirmed by
http://homeserver/dashticzbeta/vendor/d ... phpversion -> "7.4.1"
Now if i use the developer console in Chrome I first got dial.tpl not found, changed the type in config.js to regular evohome and now i got
bundle.js?t=5:305 GET http://homeserver/dashticzbeta/tpl/thermostat_evo_zone.tpl 404 (Not Found)
So i guess the path to the TPL subfolder is not correct interpreted ? Since it's definitely there...
Dashticz PHP path is default ./vendor/dashticz/ and working it seems
JSON requests to the Domoticz devices work fine.
Posted: Wednesday 30 September 2020 16:25
by Lokonli
wimmme wrote: Wednesday 30 September 2020 15:32
(1)
(2)
For the dials you don't need PHP. It's used to solve CORS issues, and for garbage and calendar functionality.
The issue is that reading the template files (.tpl) generate a 404 Not Found error. They are used for dials, evohome devices, and also for quite some other blocks.
Can you open the url in a browser window?:
http://homeserver/dashticzbeta/tpl/ther ... o_zone.tpl
Posted: Wednesday 30 September 2020 17:42
by wimmme
Lokonli wrote: Wednesday 30 September 2020 16:25
That was of great help. Got an erro in IIS, no handle. Created manually an IIS FasctCGI handler for *.tpl files via PHP and voilĂ , it works.
Does mean that a good Php installation is necessary, that wasn't the case before.
Thanks for your help !
Posted: Wednesday 30 September 2020 19:20
by Lokonli
wimmme wrote: Wednesday 30 September 2020 17:42
Glad it works. Only,I don't understand why. It seems to be an issue on Windows IIS.
Posted: Wednesday 30 September 2020 21:46
by wimmme
No idea. Maybe this might help:
mime-type type="text/x-phpbb-template"
I used this website to configure IIS on Windows 10 for PhP:
https://stackify.com/how-to-host-php-on ... -with-iis/
Working great now. Little issue when using dials: it tries to load
http://homeserver/dashticzbeta/img/fas% ... 20small_fa
that's not how fontawesome works i guess
Anyways: thanks for the help. Totally forgot about the Dev Console; not a frontend developer you know
Posted: Wednesday 30 September 2020 22:07
by Lokonli
wimmme wrote: Wednesday 30 September 2020 21:46
Fixed in latest beta
Re: [SOLVED] EvoHome devices not showing since 3.4.6
Posted: Friday 02 October 2020 9:26
by wimmme
Great, tnx !
