[SOLVED] EvoHome devices not showing since 3.4.6
I have my Evohome available in Domoticz via the web API. Working great until 3.4.5. In 3.4.5 they still show, any version after that doesn't show them.
Not the Heating zones, not the controller. Not in regular shape, not as a dial.
I tried a lot ! Clear cache, reboots, beta and master branches, total new config, starting from scratch, removing and adding devices again ...
Anyone has got their EvoHome working in dashticz in any version after 3.4.5, master or beta branch ?
Thanks in advance
Thanks in advance
Last edited by wimmme on Wednesday 30 September 2020 21:47, edited 1 time in total.
Re: EvoHome devices not showing since 3.4.6
I have it working ...wimmme wrote: ↑Wednesday 30 September 2020 12:00 Hello,
Thanks in advance
Did you set use_favorites to false in CONFIG.js?
config['use_favorites'] = false
it was on 0, tried with 0,1,false, true, removing, ...Lokonli wrote: ↑Wednesday 30 September 2020 12:10
it does show a block when using dial but nothing in it, just the title
Then we have to do some more debugging ...
(1)
In Chrome, can you open DevTools (F12), refresh Dashticz, and then post here the errors and messages in the Devtools console tab?
(2)
Can you post the output of:
http://<domoticz ip:port>/json.htm?type=devices&rid=123
replace 123 by the Domoticz device ID of your evehome devices.
(1)
(2)
Hmm, you got me on the way.Lokonli wrote: ↑Wednesday 30 September 2020 13:31 Then we have to do some more debugging ...
(1)
(2)
At first it was php not found. Could be correct since i am hosting it on Windows in IIS.
That might be a thing, don't know IIS wasn't supported.
Fixed it by installing Php in IIS. I use 7.4.1 now, confirmed by http://homeserver/dashticzbeta/vendor/d ... phpversion -> "7.4.1"
Now if i use the developer console in Chrome I first got dial.tpl not found, changed the type in config.js to regular evohome and now i got
bundle.js?t=5:305 GET http://homeserver/dashticzbeta/tpl/thermostat_evo_zone.tpl 404 (Not Found)
Dashticz PHP path is default ./vendor/dashticz/ and working it seems
JSON requests to the Domoticz devices work fine.
For the dials you don't need PHP. It's used to solve CORS issues, and for garbage and calendar functionality.wimmme wrote: ↑Wednesday 30 September 2020 15:32Hmm, you got me on the way.Lokonli wrote: ↑Wednesday 30 September 2020 13:31 Then we have to do some more debugging ...
(1)
(2)
Now if i use the developer console in Chrome I first got dial.tpl not found, changed the type in config.js to regular evohome and now i gotSo i guess the path to the TPL subfolder is not correct interpreted ? Since it's definitely there...Code: Select all
The issue is that reading the template files (.tpl) generate a 404 Not Found error. They are used for dials, evohome devices, and also for quite some other blocks.
Can you open the url in a browser window?:
http://homeserver/dashticzbeta/tpl/ther ... o_zone.tpl
That was of great help. Got an erro in IIS, no handle. Created manually an IIS FasctCGI handler for *.tpl files via PHP and voilà, it works.Lokonli wrote: ↑Wednesday 30 September 2020 16:25
Does mean that a good Php installation is necessary, that wasn't the case before.
Thanks for your help !
Glad it works. Only,I don't understand why. It seems to be an issue on Windows IIS.wimmme wrote: ↑Wednesday 30 September 2020 17:42That was of great help. Got an erro in IIS, no handle. Created manually an IIS FasctCGI handler for *.tpl files via PHP and voilà, it works.Lokonli wrote: ↑Wednesday 30 September 2020 16:25
No idea. Maybe this might help:
I used this website to configure IIS on Windows 10 for PhP: https://stackify.com/how-to-host-php-on ... -with-iis/
Working great now. Little issue when using dials: it tries to load
http://homeserver/dashticzbeta/img/fas% ... 20small_fa
that's not how fontawesome works i guess
Anyways: thanks for the help. Totally forgot about the Dev Console; not a frontend developer you know
mime-type type="text/x-phpbb-template"
Fixed in latest betawimmme wrote: ↑Wednesday 30 September 2020 21:46
Anyways: thanks for the help. Totally forgot about the Dev Console; not a frontend developer you know![]()
Re: [SOLVED] EvoHome devices not showing since 3.4.6
Great, tnx !
