updating user var to slow  [Solved]
broker
Post by broker »
it seems that I have run into a brick wall and I am in need of an extra set of eyes (more experianced!)
I am building a script for my wellpump and 3 zones that are switched via a z-wave powersocket
I want the pump to automatically start when I enable one of the zone switches for 60minutes -1 and the zone for 60minutes.
if I switch on 2 zones and switch off one zone, then the pump must continue as there is still a zone who is "asking" for water.
I have used user variables in domoticz voor_aan, achter_aan and druppelslang_aan.
what I see happening is that the pump will start how it is requested, but it will not disable.
I see that the user var seems to be changed after the script calls for the enable/disable pump function and thus sees still one zone as 'true'
is there a way how I make sure the order is done correctly and (for me) as expected? or am I missing something?
		devices = {
			'Waterpomp',
			'Sproeier Voor',
			'Sproeier Achter',
			'Druppelslang'
	    --declaratie van devices
	    local pomp          = domoticz.devices('Waterpomp')
	    local sachter       = domoticz.devices('Sproeier Achter')
	    local svoor         = domoticz.devices('Sproeier Voor')
	    local druppel       = domoticz.devices('Druppelslang')
	    --Hoelang moet er gesproeid worden
	    local sproeitijd    = 60
	    --help functie
	    local function schakelPomp(pomp,sproeitijd)
	        print("voor: "..domoticz.variables('voor_aan').value,"Achter: "..domoticz.variables('achter_aan').value,"Druppel: "..domoticz.variables('druppel_aan').value)
	        if pomp.active == false
	           then
	               pomp.switchOn().forMin(sproeitijd-1)
	               print ("Pomp gaat aan via functie")
	       elseif pomp.active == true and domoticz.variables('voor_aan').value == 'false' and domoticz.variables('achter_aan').value == 'false' and domoticz.variables('druppel_aan').value == 'false'
	           then
	                pomp.switchOff()
	                print("pomp gaat uit via functie")
            return self --om te testen dat het is gelukt
	    --pomp alleen aan, let op de druk van de pomp!
	    if
	        device.name == 'Waterpomp' and device.active == false and domoticz.variables('voor_aan').value == 'false' and domoticz.variables('achter_aan').value == 'false' and domoticz.variables('druppel_aan').value == 'false'
    	    then
    	        device.switchOff().afterMin(sproeitijd)
    	       print("pomp aan via schakelaar")
        --Sproeier in voortuin aan
        elseif
            device.name == 'Sproeier Voor'
            then
                if device.active
                    then
                        svoor.switchOff().afterMin(sproeitijd)
                        domoticz.variables('voor_aan').set('true')
                        print('Voor aan')
                        domoticz.variables('voor_aan').set('false')
                        print("Voor uit")
        --Sproeier in achtertuin aan
        elseif
            device.name == 'Sproeier Achter'
	        then
	            if device.active
	                then
                        sachter.switchOff().afterMin(sproeitijd)
                        domoticz.variables('achter_aan').set('true')
                        print("Achter aan")
                        domoticz.variables('achter_aan').set('false')
                        print("achter uit")
        --Druppelslang voor en achter
        elseif
            device.name == 'Druppelslang'
            then
                if device.active
                    then
                        druppel.switchOff().afterMin(sproeitijd)
                        domoticz.variables('druppel_aan').set('true')
                        print("Druppel aan")
                        domoticz.variables('druppel_aan').set('false')
                        print("Druppel uit")
Re: updating user var to slow
broker wrote: Monday 21 September 2020 15:52 it seems that I have run into a brick wall and I am in need of an extra set of eyes (more experianced!)
What I see is that you set the uservariables to 'false' and in the same execution of the script check if the value is 'false'
This does not work in eventscripts because the actual change of the var (and also the switch of a device) will only happen after the script finished. The commands are send back to domoticz and the domoticz main process will perform the actions.
If you want variables to be interpreted during the same execution of the script and also in other runs of the same script you need to change them to dzVents persistent variables.
broker
Post by broker »
Thanks, I was not aware of that fact, I just read up on the persistent vars and I will change it and check if it works!
broker
Post by broker »
hmm, I guess I am in need of some more advice, I guess I am using the persistent variable wrong, can some one please have a look. if I execute one of the zones, i get this message: Error: dzVents: Error: (3.0.4) .../domoticz/scripts/dzVents/generated_scripts/pomp_lua.lua:57: attempt to index a nil value (field 'data') I am also not sure if I can use actual booleans here, so I reverted to string checking.
		devices = {
			'Waterpomp',
			'Sproeier Voor',
			'Sproeier Achter',
			'Druppelslang'
		data = {
		    voor_aan    = {initial='false'},
		    achter_aan  = {initial='false'},
		    druppel_aan = {initial='false'}
	    --help functie
	        --print("voor: "..domoticz.variables('voor_aan').value,"Achter: "..domoticz.variables('achter_aan').value,"Druppel: "..domoticz.variables('druppel_aan').value)
	           then
	       elseif pomp.active == true and domoticz.data.voor_aan == 'false' and domoticz.data.achter_aan == 'false' and domoticz.data.druppel_aan == 'false'
	           then
	                pomp.switchOff()
	    if
	        device.name == 'Waterpomp' and domoticz.data.voor_aan == 'false' and domoticz.data.achter_aan == 'false' and domoticz.data.druppel_aan == 'false'
    	    then
        elseif
            then
                if device.active
                    then
                        domoticz.data.voor_aan = 'true'
                        print('Voor aan')
                        domoticz.data.voor_aan = 'false'
                        print("Voor uit")
        elseif
	        then
	            if device.active
	                then
                        domoticz.data.achter_aan = 'true'
                        print("Achter aan")
                        domoticz.data.achter_aan = 'false'
                        print("achter uit")
        elseif
            then
                if device.active
                    then
                        domoticz.data.druppel_aan = 'true'
                        domoticz.data.druppel_aan = 'false'
broker wrote: Monday 21 September 2020 22:47 hmm, I guess I am in need of some more advice, I guess I am using the persistent variable wrong, can some one please have a look. if I execute one of the zones, i get this message: Error: dzVents: Error: (3.0.4) .../domoticz/scripts/dzVents/generated_scripts/pomp_lua.lua:57: attempt to index a nil value (field 'data') I am also not sure if I can use actual booleans here, so I reverted to string checking.
You misplaced one }
dzvents now sees data as part of the on = section
the data can be boolean.
Should look like
return
    on =
        devices =
            'Waterpomp',
            'Sproeier Voor',
            'Sproeier Achter',
            'Druppelslang'
    data =
            voor_aan    = { initial = 'false' },
            achter_aan  = { initial = 'false' },
            druppel_aan = { initial = 'false' },
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Waterpomp',
broker
Re: updating user var to slow  [Solved]
Post by broker »
lol that makes sense, thanks!
its good to make mistakes, now I learned what to look for in my other scripts, as I am converting my blockly to dzvents.
