json url with username and password Topic is solved
Rebecca
In domoticz, I created a virtual switch, and set on action to trigger another virtual switch to turn on using json. Something like: http://192.168.1.2:8080/json.htm?type=c ... &svalue=79.
After I added username and password, this url is of course not working anymore.
Following the instructions in https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s, I tried:
- http://<user:pwd>@hostname
- http://domoticz-ip<:port>/json.htm?username=<encrypted username>&password=<encrypted pwd>&api-call
But both of the methods give me a 401 unauthorized error.
Somebody could help here?
- waaren
Re: json url with username and password
Below call works for meRebecca wrote: Wednesday 16 September 2020 17:26 I tried:
http://waaren:[email protected]:8084/json.htm?type=command¶m=getversionDebian buster, bullseye on RPI-4, Intel NUC.
Rebecca
Thanks Waaren. I tried the same, doesn't work for me. Also tried it in different browsers
- waaren
How did you configure your website protection? Mine isRebecca wrote: Thursday 17 September 2020 12:04 Thanks Waaren. I tried the same, doesn't work for me. Also tried it in different browsers.
Rebecca
I configure the website protection the same as yours.
- waaren
And does this user have admin rights?
ThomasZA
I have the same issue, tried both auth types... with and without admin rights on the user....
My local access works... my access using the same URL's from my phone (not on my wifi) works fine....
using the same auth either from ifttt or friends in another country does not work... 401 error
Not too sure what else to try - it used to work before (granted a long time ago - and I am only looking at it now)
So something must have changed in how domoticz handles these json url's, or its security then?
