Turn dummy switch on when domoticz starts up  [Solved]
knireis
Post by knireis »
I'm trying to get a dzVents script going which turns a switch on when domoticz starts up.
But i am quite a noob in scripting and can not get it to work.
And i can not find a likewise example on the internet.
This i made sofar but it does not do the trick. (Linphone-S is the switch)
		system = {
			'start',
		devices = {'Linphone-S'
	domoticz.switches('Linphone-S').switchOn()
the log:
2020-09-13 20:34:07.969 Error: dzVents: Error: (3.0.12) error loading module 'linphone-init' from file '/opt/domoticz/scripts/dzVents/generated_scripts/linphone-init.lua':
2020-09-13 20:34:07.969 ...ticz/scripts/dzVents/generated_scripts/linphone-init.lua:6: '}' expected (to close '{' at line 2) near 'devices'
Any suggestions?
niki_lauda
Re: Turn dummy switch on when domoticz starts up
Post by niki_lauda »
Maybe you can scan the log file for a restart and flip the switch.
viewtopic.php?f=61&t=28299&hilit=getDom ... og#p216802
knireis wrote: Sunday 13 September 2020 20:13 I'm trying to get a dzVents script going which turns a switch on when domoticz starts up.
Any suggestions?
can you try this?
return
    on =
        system =
            'start',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'start',
    execute = function(dz)
        dz.devices('Linphone-S').switchOn()
niki_lauda wrote: Sunday 13 September 2020 20:30 Maybe you can scan the log file for a restart and flip the switch.
If you are on dzVents version >= 3.0 that's no longer needed. See example in my previous post.
knireis
Re: Turn dummy switch on when domoticz starts up  [Solved]
Post by knireis »
waaren wrote: Sunday 13 September 2020 20:33 can you try this?
Hey thanks, now it works!
