zwave problem or Domoticz?
Posted: Saturday 12 September 2020 10:12
by ropske
Hi, i'm having a weird problem with some zwave devices.
See one of them here:
In this example i'm using a: FIBARO System FGS222 Double Relay Switch 2x1.5kW
Sometimes in Domoticz the status is on:
- 2020-09-12 10_04_07_01-Domoticz.jpg (12.87 KiB) Viewed 1527 times
But when i check the fysical condition in real live, the status is off; also when i check the Zwave control panel, there it also shows off:
- 2020-09-12 10_05_30-OpenZWave Control Panel.jpg (10.96 KiB) Viewed 1527 times
My groups seems ok:
- 2020-09-12 10_04_07_02-Domoticz.jpg (31.27 KiB) Viewed 1527 times
Is this something with Domoticz getting the wrong value?
I'm using Domoticz 2020.2 on an Intel NUC with AEON Labs ZW090 Z-Stick Gen5 EU
Re: zwave problem or Domoticz?
Posted: Monday 14 September 2020 17:23
by commentator
Posted: Monday 14 September 2020 17:24
by commentator
glad to see an other person with same problem. Waiting for a fix since December 2018 ....
Posted: Wednesday 11 November 2020 15:48
by ropske
@gizmocus, can you please take a look?
I'm not the only one with the problem.
I already tried with a complete new fresh install, in the beginning all fine for me and after some weeks it begins....
Like for example now, my gasheater says in Domoticz it is on. But when i check the openzwave control panel it shows :OFF and when i check the actual situation of the gasheater, if is also OFF, so seems Domoticz is interpreting the values wrong from Openzwave.
Thank you
Posted: Tuesday 17 November 2020 11:19
by mrfusion
I seems to face the same problem.
I don't know if it is helping or 100% true statement but for me the issue apparently happens when I manipulate the device with an LUA Script (randomly shows On while it is physically Off and also in Zwave CP).
I mean: I have a Qubino Din Dimmmer and its status is getting wrong after being manipulated by a LUA or DZ event but seems fine when manipulated from devicet itself (wall switch ) or Domoticz web UI.
Anyone seeing the same?
Posted: Tuesday 17 November 2020 12:44
by mrfusion
Well actually even after disabling the LUA script using it, the device randomly shows "On".
See attached screenshot.
