zwave problem or Domoticz?
ropske
Domoticz version: V3_8394
Post by ropske »
Hi, i'm having a weird problem with some zwave devices.
See one of them here:
In this example i'm using a: FIBARO System FGS222 Double Relay Switch 2x1.5kW
Sometimes in Domoticz the status is on:
2020-09-12 10_04_07_01-Domoticz.jpg (12.87 KiB) Viewed 1526 times
But when i check the fysical condition in real live, the status is off; also when i check the Zwave control panel, there it also shows off:
2020-09-12 10_05_30-OpenZWave Control Panel.jpg (10.96 KiB) Viewed 1526 times
My groups seems ok:
2020-09-12 10_04_07_02-Domoticz.jpg (31.27 KiB) Viewed 1526 times
Is this something with Domoticz getting the wrong value?
I'm using Domoticz 2020.2 on an Intel NUC with AEON Labs ZW090 Z-Stick Gen5 EU
commentator
Re: zwave problem or Domoticz?
Post by commentator »
commentator
glad to see an other person with same problem. Waiting for a fix since December 2018 ....
ropske
Post by ropske »
@gizmocus, can you please take a look?
I'm not the only one with the problem.
I already tried with a complete new fresh install, in the beginning all fine for me and after some weeks it begins....
Like for example now, my gasheater says in Domoticz it is on. But when i check the openzwave control panel it shows :OFF and when i check the actual situation of the gasheater, if is also OFF, so seems Domoticz is interpreting the values wrong from Openzwave.
Thank you
mrfusion
Post by mrfusion »
I seems to face the same problem.
I don't know if it is helping or 100% true statement but for me the issue apparently happens when I manipulate the device with an LUA Script (randomly shows On while it is physically Off and also in Zwave CP).
I mean: I have a Qubino Din Dimmmer and its status is getting wrong after being manipulated by a LUA or DZ event but seems fine when manipulated from devicet itself (wall switch ) or Domoticz web UI.
Anyone seeing the same?
mrfusion
Post by mrfusion »
Well actually even after disabling the LUA script using it, the device randomly shows "On".
See attached screenshot.
