Check if value changed
Posted: Thursday 10 September 2020 22:18
by Jumper3126
the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
Re: Check if value changed
Posted: Thursday 10 September 2020 22:29
by waaren
Jumper3126 wrote: Thursday 10 September 2020 22:18 the lastupdate feature of DZventz is enormously handy, but for a new script I would like to know when a device (integer value) has changed. This specific devices is updated every minute but also if the value didn't change. Is this possible somehow or do i need to work with persistent data to store and compare?
Yes you need to work with persistent data or a domoticz uservariable to compare current state with a previous state if your device is not a dimmer or selector. For these types you can use the lastLevel attribute.
Re: Check if value changed  [Solved]
Posted: Thursday 10 September 2020 22:39
by Jumper3126
Thanks for that very quick respons waaren!
Posted: Wednesday 23 September 2020 16:27
by Patricen
This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
using my algorithmic language it would look like
If sensor above stove's dewpoint rose more than 1°C since last update
Set cooker hood to "on"
Posted: Wednesday 23 September 2020 22:54
by waaren
Patricen wrote: Wednesday 23 September 2020 16:27 This looks like it could solve my issue. I would like to trigger an event on sudden dewpoint rise. Do you have any example showing this?
Something like below ?
return
    on =
        devices =
            'myDewpointSensor', -- change to name of Sensor
    data =
        lastValue =
            initial = 0,
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script is tested and OK
        marker = 'dewPoint-rise',
    execute = function(dz, item)
        cookerHood = dz.devices('cooker hood') -- change to name of Cooker Hood device
        dz.log('\nDevicename: ' .. item.name .. ', nValue: ' .. item.nValue .. ', sValue: ' .. item.sValue ..
               '\nDevicetype: ' .. item.deviceType .. ', deviceSubType: ' .. item.deviceSubType ..
               '\nlastValue: ' .. dz.data.lastValue, dz.LOG_DEBUG )
        if item.dewPoint >=  dz.data.lastValue + 1 then
            cookerHood.switchOn().checkFirst()
        if dz.data.lastValue ~= item.dewPoint then
            dz.data.lastValue = item.dewPoint
Posted: Friday 25 September 2020 12:03
by Patricen
Thanks a lot, I'll try this and keep you updated
Posted: Friday 25 September 2020 14:02
by Patricen
waaren wrote: Wednesday 23 September 2020 22:54
return
    on =
        devices =
    data =
        lastValue =
            initial = 0,
    logging =
Waahh!! Brilliant, this works like a charm, thanks!
