2020-09-02 18:12:15.687 Status: BuienRadar: using Domoticz location settings (56.876897,24.158779)
2020-09-02 18:12:15.687 Error: BuienRadar: No (nearby) station found!
2020-09-02 18:12:20.494 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-09-02 18:13:02.147 Status: BuienRadar: Worker stopped...
2020-09-02 18:13:02.147 Status: BuienRadar: Worker started...
2020-09-02 18:13:09.518 Status: BuienRadar: using Configured location settings (56.876897, 24.158779)
2020-09-02 18:13:09.518 Error: BuienRadar: No (nearby) station found!
2020-09-02 18:13:14.156 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
Hardware added, no devices appears, see messages from log ^^
BuienRadar not creating devices
- kiddigital
Re: BuienRadar not creating devices
Which makes sense from your log as Buienradar is unable to determine a location. Make sure you configure the home location of Domoticz in your settings.
Once it finds a nearby station, it will read data from that station and after succesful reading the data it will try to create the devices.
It didn’t reach that point looking at your logs.
- waaren
lat/lon 56.876897, 24.158779 is nowhere near a dutch weatherstation.Masterz wrote:
Native Buienradar module is for Dutch locations only.
boskant
- Domoticz version: V4.10717
I dont use the buienradar script, i use my own.
I did notice when creating/modifieing the script then number of the wheterstaion did not match up.
Below numbers did work for me
--[[ WEERSTATIONS:
1 - Arcen 13 - Groningen 25 - LE Goeree 37 - Stavenisse 49 - Wijk aan Zee
2 - Arnhem 14 - Hansweert 26 - Leeuwarden 38 - Stavoren 50 - Woensdrecht
3 - Berkhout 15 - Heino 27 - Lelystad 39 - Texelhors 51 - Zeeplatform F-3
4 - Cadzand 16 - Herwijnen 28 - Lopik-Cabauw 40 - Tholen 52 - Zeeplatform K13
5 - De Bilt 17 - Hoek van Holland 29 - Maastricht 41 - Twente
6 - Den Helder 18 - Hoogeveen 30 - Marknesse 42 - Vlakte aan de Raan
7 - Eindhoven 19 - Hoorn Terschelling 31 - Nieuw Beerta 43 - Vlieland
8 - Ell 20 - Houtribdijk 32 - Oosterschelde 44 - Vlissingen
9 - Euro platform 21 - Huibertgat 33 - Rotterdam 45 - Volkel
10 - Gilze Rijen 22 - IJmond 34 - Rotterdam Geulhaven 46 - Voorschoten
11 - Goes 23 - IJmuiden 35 - Schaar 47 - Westdorpe
12 - Groenlo-Hupsel 24 - Lauwersoog 36 - Schiphol 48 - Wijdenes
--[[ WEERSTATIONS:
