WGR800 <> WTGR800 number of parameters
Soundmanbe
Post by Soundmanbe »
I haven't the possibility to use my WGR800 Oregon to show the wind speed and direction.
The wind configuration in Domo require 5 parameters :
Expecting svalue with at least 5 elements separated by semicolon, 3 elements received ("0.0;82;3"), notification not sent (Hardware: 3 - Météo, ID: 82008, Unit: 1, Type: 56 - Wind, SubType: 1 - WTGR800
But this is for the unit WTGR800, WGR800 only send 3 parameters.
How can I force to use only the 3 parameters ?
Installation on NAS synology.
THX.
Soundmanbe
Re: WGR800 <> WTGR800 number of parameters
I changed the LUA script taking the information from a Zibase to add 2 fields for test. The strange thing is a " 0, " arriving in the data not sent from the lua script
But no way to have any showed information in the meteo and no graphic, no data in the log.
Any suggestion is welcome.
kind regards
Soundmanbe wrote: Wednesday 26 August 2020 15:27 I changed the LUA script taking the information from a Zibase to add 2 fields for test. The strange thing is a " 0, " arriving in the data not sent from the lua script
kind regards
If you share the Lua script someone might be able to help.
