I have a dimmer (Qubino DIN Dimmer) and I'd like to restart it from 0 (or 1) when I switched it on after an off.
For instance 0 -> 5% -> 0 -> 55% -> 0 -> 100%
Without anything when I switch it on it restarts from the last on level !
I've tried those settings on the device:
67. Ignore start level: ignore start level
68. Dimming duration: Ignore start level
w/o success
So I wrote this script
local LED_SWITCH = 1023 -- dimmer switch
logging = { level =
--domoticz.LOG_ERROR,
domoticz.LOG_DEBUG,
--domoticz.LOG_INFO,
--domoticz.LOG_FORCE
devices = {LED_SWITCH},
execute = function(dz, device)
_G.logMarker = dz.moduleLabel -- set logmarker to scriptname
local LOG_LEVEL = dz.LOG_DEBUG
dz.log(device.name .. " " .. device.state .. " " .. tostring(device.level) .. " nValue: " .. device.nValue, LOG_LEVEL)
local function logWrite(str,level)
if level == nil then
level = LOG_LEVEL
dz.log(tostring(str),level)
local toDo
if device.active then
dz.log(device.name .. " level: " .. device.level, LOG_LEVEL)
toDo = device.level
logWrite('toDo: ' .. toDo)
--device.dimTo(0).silent()
toDo = 0
--device.switchOn().silent()
device.dimTo(1).silent()
--device.setLevel(1).silent()
device.switchOff().silent().afterSec(1)
logWrite('TO OFF')
}So the device it set to level on 1 when off.
But when I switched it on again it restarts from the previous level
I've tried to change these settings
w/o success
Version: 2020.2 (build 12269)
Build Hash: 81b1d645b-modified
Compile Date: 2020-08-23 17:33:23
dzVents Version: 3.0.11
It seemed to have worked yesterday with a previous version, but I didn't managed to make it works again
