Shelly MQTT readonly
Posted: Friday 14 August 2020 15:51
by gomsoo
I've severals Shelly 1, I can only read the status
I get the switch, witch indicates the status properly. But when I click on this device, I get the message "Switching On", but nothing happen.
As workaround I create a dummy switch and control the shelly with a http request, but this is not a useful solution.
Has anybody an idea how I can control the shelly directly?
Re: Shelly MQTT readonly
Posted: Friday 14 August 2020 22:48
by FireWizard
Your post is not really clear for me, but is it your setting in MQTT hardware of "Prevent Loop"?
See:
https://www.domoticz.com/forum/viewtopi ... t&start=20 (post 08 Apr 2020, 16:46)
Posted: Monday 17 August 2020 10:37
by gomsoo
Thanks for your answer
I've the plugin Shelly MQTT and don't have the option "prevent loop".
With this plugin I can only read all stats of each shelly devices, works fine, but I can't control them.
Posted: Monday 17 August 2020 21:18
by lwolf
gomsoo wrote: Monday 17 August 2020 10:37
It is happening when you are enabling "Use custom MQTT prefix" feature. Status messages will come, but commands will never go through as the mqtt path hold necessary informations for the plugin.
Posted: Monday 17 August 2020 21:42
by gomsoo
I researched and find the solution
Don't use prefixes, and it works like a charme
I seems we find at the same time this solution, but anyway, thanks a lot
