Domoticz graph with 2 value's for PV inverter
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
I recently changed my PV inverter for a unit with 2 mppt trackers.
I use a script to read the data from the old inverter with this script
https://www.domoticz.com/wiki/Omnik_Solar_Inverter
luckaly the script can read inverters with 2 mppt tracker , so i did not have to change much. only give the second value an IDX value.
Because every mppt has his own PV set, the production curve is differten, also due to oriantation. The total Power output is recorded , but not the mppt 1 and 2 value. Omnik U PV1 x Omnik I PV1 =power PV1. Omnik U PV2 x Omnik I PV2 =power PV2. so the values are there.
Is it possible to make a custom graph with these PV1 and PV2 values during the day? like in the attachement
