I migrated from vera to domoticz an it. I really like domoticz so far, but I miss the stop function on the roller shutter.
I use a FIBARO System FGR221 Roller Shutter Controller that is recognized as a switch. I changed it to blinds inverted to match the open and close function. But I would really like to be able to half open the shutter. % did not work. Venetian blinds did sometimes kind of work. (It changed direction and stopped after about 15 seconds)
On vera I had up/stop/down buttons that worked immediately.
How can I configure the shutters to match my needs?
Greets
paede
Stop Function on Fibaro Roller Shutter Topic is solved
- Treve
- Domoticz version: v4.11474
If you choose “blinds percentage “?
I have the same fibaro controller and it works good.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
zanna1972
- Domoticz version: 2020.2
Re: Stop Function on Fibaro Roller Shutter
Hi, I have two FGR221 configured as Blinds inverted. I can open/close but I can't set a percentage. My problem is that the "status" shown in Domoticz is wrong, I mean it shows "Open" when it's closed. Do you know why?
I have also one FGRM222 and it is perfectly running. I can set percentage and also get the correct status.
