Yet another broken Zigate?
mpx2
Domoticz version: 4.10717
Post by mpx2 »
Zigates USB-TTL has broken two times. This time the LEDs will turn on but Raspberry Pi won't detect Zigate. Dmesg will report these errors.
[  288.386991] usb 1-1.1.3: USB disconnect, device number 5
[  288.387010] usb 1-1.1.3.4: USB disconnect, device number 6
[  326.336875] usb 1-1.3: new full-speed USB device number 11 using dwc_otg
[  326.436877] usb 1-1.3: device descriptor read/64, error -32
[  326.656872] usb 1-1.3: device descriptor read/64, error -32
[  326.876872] usb 1-1.3: new full-speed USB device number 12 using dwc_otg
[  326.976875] usb 1-1.3: device descriptor read/64, error -32
[  327.196876] usb 1-1.3: device descriptor read/64, error -32
[  327.317018] usb 1-1-port3: attempt power cycle
[  327.976883] usb 1-1.3: new full-speed USB device number 13 using dwc_otg
[  328.417027] usb 1-1.3: device not accepting address 13, error -32
[  328.516897] usb 1-1.3: new full-speed USB device number 14 using dwc_otg
[  328.956895] usb 1-1.3: device not accepting address 14, error -32
[  328.957042] usb 1-1-port3: unable to enumerate USB device
pipiche
Re: Yet another broken Zigate?
Post by pipiche »
What is your setup ? what is your OS distribution ? How is the ZiGate connected to the PI? Which version of PI are you using , what model of Zigate to you use ?
If you are on a PI4, I think that you MUST use not use the USB3 port
ronaldbro
Post by ronaldbro »
mpx2
Post by mpx2 »
pipiche wrote: Tuesday 21 July 2020 8:44 What is your setup ? what is your OS distribution ? How is the ZiGate connected to the PI? Which version of PI are you using , what model of Zigate to you use ?
I reinstalled everything.
Rasbian Buster
Raspberry Pi 3 Model B Plus Rev 1.3
Domotics Version: 2020.2 (build 12230)
ZiGate USB-TTL with blue USB-TTL, firmware 3.1c
USB-hub or 30 cm USB-C cable in between Zigate and Raspberry Pi.
Voltage level is 5,05 V
Windows cannot use it either.
Device USB\VID_0000&PID_0002\5&397c2be2&0&6 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_14ED&PID_2904\6&1b9afb93&0&1
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Location Path:
Migration Rank: 0xF000FFFFFFFFF120
Present: false
Status: 0xC0000719
pipiche
Post by pipiche »
It might be better to contact the vendor, as this looks more an hardware issue (if it doesn't work either with Windows)
mpx2
Post by mpx2 »
Yes the USB TTL was broken, again!
