Page 1 of 3
Multi-day weather forecast to control device
Posted: Sunday 19 July 2020 8:57
by Atis
I would like Multi-day weather forecast to control device. How can I set up that I can Using the forecast to control domoticz device?
I see 8 day forecast in domoticz, but I can not use this information to control the sprinkler or something else.
i added another weather forecast but in domoticz it only shows the current value.
I need temperature and rain forecast. Possibly if the amount of precipitation can be solved.
Thank you,
Re: Multi-day weather forecast to control device
Posted: Sunday 19 July 2020 12:55
by waaren
Atis wrote: Sunday 19 July 2020 8:57 I would like Multi-day weather forecast to control device. How can I set up that I can Using the forecast to control domoticz device?
This information can be collected from openweathermap.org if you have a (free) API key and can be processed using a dzVents script.
What would you like to see in domoticz based on the data from openwathermap and on what devicetype(s)?
How would the control need to look like if you know the expected average-, min- and max temperatures and the expected amount of rain in mm per day for the next 7 days?
Posted: Monday 20 July 2020 8:10
by Atis
waaren wrote: Sunday 19 July 2020 12:55
Hello Waaren,
I think 5-7 days max. celsius forecast divided into days. This info in temperatures sheet.
The rain data in mm for the next 5-7 days in weather sheet.
Posted: Monday 20 July 2020 13:27
by waaren
Atis wrote: Monday 20 July 2020 8:10 I think 5-7 days max. celsius forecast divided into days. This info in temperatures sheet.
Could look like below. rain forecast data is in custom sensors (in the utility tab)
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
        This script collects rain en temperature forecast data from openweathermap.org
        You need a free API key to access this data. Read howto get this free API key
        at https://openweathermap.org/guide#how
        Next you need to create a uservariable (type string) and enter the openweathermap API key as value
        Then create the devices
local scriptVar = 'openWeatherMap'
return
        timer =
            'at 05:17' -- Once a day should be enough
        devices =
            scriptVar .. 'Trigger', -- only used for testing
        httpResponses =
            scriptVar
    logging =
            level = domoticz.LOG_DEBUG, -- switch to domoticz.ERROR when script works as designed
            marker = scriptVar,
    execute = function(dz, item)
       -- ******** enter names of vars and devices below this line
        local openWeatherAPIKey = dz.variables('openWeatherAPIKey').value -- Type string var required
        local currentRain = dz.devices('Rain today')         -- optional virtual Custom Sensor
        local rain48Hours = dz.devices('Rain 48 hours')      -- optional virtual Custom Sensor
        local rain8Days = dz.devices('Rain 8 days')          -- optional virtual Custom Sensor
        local weatherText = dz.devices('WeatherForecast')    -- optional text Sensor
        local currentTemperature = dz.devices('Current Temperature') -- Optional virtual Temperature sensor
        local temperature48Hours = dz.devices('Max Temperature next 48 hours') -- Optional virtual Temperature sensor
        local temperature8Days = dz.devices('Max Temperature next 8 days') -- Optional virtual Temperature sensor
       -- ******** No changes required below this line
        local openWeatherURL = 'https://api.openweathermap.org/data/2.5/onecall?&units=metric'
        local function getCurrentRain(t)
            if t == nil then return 0 end
            local totalmm = 0
                for key, mm in pairs(t) do
                    totalmm = totalmm + mm
            return totalmm
        local function get8DaysMaxTemperature(t)
            local maxTemperature = -100
            for _, record in ipairs(t) do
                if record.temp.max > maxTemperature then maxTemperature = record.temp.max end
            return dz.utils.round(maxTemperature,1)
        local function get48HoursMaxTemperature(t)
                if record.temp > maxTemperature then maxTemperature = record.temp end
        local function get48HoursRain(t)
            local totalmm = 0
            for key, record in ipairs(t) do
                if type(record) == 'table' and record.rain ~= nil then
                    for id, mm in pairs(record.rain) do
                        dz.log(id)
            return totalmm
        local function get8DaysRain(t)
            local totalmm = 0
                        totalmm = totalmm + record.rain
            return totalmm
        local function createResultTable(rt)
            rt.currentRain = getCurrentRain(rt.current.rain)
            rt.rain48Hours = get48HoursRain(rt.hourly)
            rt.rain8Days = get8DaysRain(rt.daily)
            rt.temperature48Hours = get48HoursMaxTemperature(rt.hourly)
            rt.temperature8Days = get8DaysMaxTemperature(rt.daily)
        local function updateTextDevice(t)
            local text =   'range:          rain - max Temp'  .. '\n'
            text = text .. 'current:   ' .. t.currentRain .. ' mm, ' .. t.current.temp .. ' °C' .. '\n'
            text = text .. '48 hours:  ' .. t.rain48Hours .. ' mm, ' .. t.temperature48Hours .. ' °C' .. '\n'
            text = text .. '8 days:    ' .. t.rain8Days .. ' mm, ' .. t.temperature8Days .. ' °C' .. '\n'
            weatherText.updateText(text)
        local function deviceExists(dv)
            if dv == nil then
                return false
                return dz.utils.deviceExists(dv.name)
        local function updateDevices(rt)
            if deviceExists(currentRain) then currentRain.updateCustomSensor(rt.currentRain) end
            if deviceExists(rain48Hours) then rain48Hours.updateCustomSensor(rt.rain48Hours) end
            if deviceExists(rain8Days) then rain8Days.updateCustomSensor(rt.rain8Days) end
            if deviceExists(currentTemperature) then currentTemperature.updateTemperature(rt.current.temp) end
            if deviceExists(temperature48Hours) then temperature48Hours.updateTemperature(rt.temperature48Hours) end
            if deviceExists(temperature8Days) then temperature8Days.updateTemperature(rt.temperature8Days) end
            if deviceExists(weatherText) then updateTextDevice(rt) end
        -- main code
        if item.isHTTPResponse then
            if item.ok and item.isJSON then
                local rt = item.json
                updateDevices(rt)
                dz.log('There was a problem with the response from ' .. scriptVar, dz.LOG_ERROR)
                dz.log(item, dz.LOG_DEBUG)
        else -- get the data from openweatherMap
            dz.openURL({
                url = openWeatherURL  ..
                      '&lat=' .. dz.settings.location.latitude ..
                      '&lon='  .. dz.settings.location.longitude ..
                      '&appid=' .. openWeatherAPIKey,
                callback = scriptVar, -- see httpResponses above.
Posted: Tuesday 21 July 2020 9:22
by Atis
waaren wrote: Monday 20 July 2020 13:27
Hello Waaren, Thank you your script. Script is working but I have the problem with data:
Temperature: The script said 48 h and next 8 days max temp. 24.7 and 24.6. But I see the openwethermap page the teperature in next 8 day max 28-30Celsius.
Rain forecast: The domoticz said no rain today and the next 48 hours. But the wether site said light rain tomorrow 0,34 mm/h. 8 days rain forecast data not right. Can you help me?
Posted: Tuesday 21 July 2020 12:06
by waaren
Atis wrote: Tuesday 21 July 2020 9:22 Script is working but I have the problem with data:
The only things that can cause this are different lat / lon settings in domoticz compared to what you entered on the site or a problem at the openweathermaps.org site's data. The script will only process the data it gets from the site by summing, determining the max. There is no other interpretation in the script.
The figures I get using this API, match with what I see on the openweathermap for my city.
Posted: Tuesday 21 July 2020 19:39
by Atis
waaren wrote: Tuesday 21 July 2020 12:06
Which api using from weather api?
I have this:
Weather Current weather and forecast Free plan Hourly forecast: unavailable
Daily forecast: unavailable
Calls per minute: 60
3 hour forecast: 5 days
I see in json that correct rain and temp, but in domoticz data not good. I dont understand.
Posted: Tuesday 21 July 2020 20:00
by waaren
Atis wrote: Tuesday 21 July 2020 19:39 Which api using from weather api?
The one used in the script
https://api.openweathermap.org/data/2.5/onecall?&units=metric&lat=<your lat>&lon=<your lon>appid=<your appid>
and compared with
Posted: Tuesday 21 July 2020 20:43
by Atis
Tomorrow json:
dt	1595412000
sunrise	1595387383
sunset	1595442632
temp
day	23.03
min	20.23
max	28.27
night	23.58
eve	28.26
morn	22.22
feels_like
day	24.32
night	23
eve	26.67
morn	22.86
pressure	1020
humidity	65
dew_point	16.22
wind_speed	1.04
wind_deg	339
weather
0
id	501
main	"Rain"
description	"moderate rain"
icon	"10d"
clouds	100
pop	0.92
rain	8.95
uvi	8.11
Domoticz said no rain and 26.1 max temp. In setup long and latitude correct.
Posted: Tuesday 21 July 2020 22:40
by waaren
Atis wrote: Tuesday 21 July 2020 20:43 rain 8.95
uvi 8.11
Can you please share your lat /lon (use PM ) to help me debug ?
I guessed Budapest and the data from openweathermap GUI matches the API exactly when grabbed at the same time. Maybe the script execution frequency should go to once per hour if you want it to be more accurate for the next couple of hours ?
What devices are you looking at and have you executed the script just before comparing it with the call from your GUI ?
This is what I see and that looks about right
Posted: Wednesday 22 July 2020 13:12
by Jan Jansen
@ waaren,
Thanks for sharing your nice script! I want to add the minimum temperatures but I get an error that I can't resolve myself.
return
        timer =
            'at 12:35' -- Once a day should be enough
        devices =
        httpResponses =
            scriptVar
    logging =
            marker = scriptVar,
        local temperaturemax48Hours = dz.devices('Max Temperature next 48 hours') -- Optional virtual Temperature sensor
        local temperaturemin48Hours = dz.devices('Min Temperature next 48 hours') -- Optional virtual Temperature sensor
        local temperaturemax8Days = dz.devices('Max Temperature next 8 days') -- Optional virtual Temperature sensor
	 	local temperaturemin8Days = dz.devices('Min Temperature next 8 days') -- Optional virtual Temperature sensor
            local totalmm = 0
            return totalmm
        local function get8DaysMinTemperature(t)
            local minTemperature = -100
                if record.temp.min < minTemperature then maxTemperature = record.temp.min end
            return dz.utils.round(minTemperature,1)
                if record.temperature.max > maxTemperature then maxTemperature = record.temperature.max end
        local function get48HoursMinTemperature(t)
                if record.temperature.min < minTemperature then minTemperature = record.temperature.min end
            local totalmm = 0
                        dz.log(id)
            return totalmm
            local totalmm = 0
            return totalmm
            rt.temperaturemax48Hours = get48HoursMaxTemperature(rt.hourly)
            rt.temperaturemin48Hours = get48HoursMinTemperature(rt.hourly)
            rt.temperaturemax8Days = get8DaysMaxTemperature(rt.daily)
            rt.temperaturemin8Days = get8DaysMinTemperature(rt.daily)
            if dv == nil then
                return false
            if deviceExists(temperature48Hours) then temperature48Hours.updateTemperature(rt.temperaturemax48Hours) end
            if deviceExists(temperature48Hours) then temperature48Hours.updateTemperature(rt.temperature48minHours) end
            if deviceExists(temperature8Days) then temperature8Days.updateTemperature(rt.temperaturemax8Days) end
            if deviceExists(temperature8Days) then temperature8Days.updateTemperature(rt.temperaturemin8Days) end
        -- main code
                updateDevices(rt)
            dz.openURL({
 2020-07-22 12:35:00.617 Status: dzVents: Info: openWeatherMap: ------ Start internal script: Script #1:, trigger: "at 12:35"
2020-07-22 12:35:00.656 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain today: Custom sensor device adapter
2020-07-22 12:35:00.659 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain 48 hours: Custom sensor device adapter
2020-07-22 12:35:00.662 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain 8 days: Custom sensor device adapter
2020-07-22 12:35:00.665 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for WeatherForecast: Text device
2020-07-22 12:35:00.668 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Current Temperature: Temperature device adapter
2020-07-22 12:35:00.670 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Max Temperature next 48 hours: Temperature device adapter
2020-07-22 12:35:00.673 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Min Temperature next 48 hours: Temperature device adapter
2020-07-22 12:35:00.675 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Max Temperature next 8 days: Temperature device adapter
2020-07-22 12:35:00.677 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Min Temperature next 8 days: Temperature device adapter
2020-07-22 12:35:00.678 Status: dzVents: Debug: openWeatherMap: OpenURL: url = https://api.openweathermap.org/data/2.5/onecall?&units=metric&lat=51.8556&lon=5.8417&appid=1850f4e69177e9bd9f219ddbd525ab29
2020-07-22 12:35:00.678 Status: dzVents: Debug: openWeatherMap: OpenURL: method = GET
2020-07-22 12:35:00.678 Status: dzVents: Debug: openWeatherMap: OpenURL: post data = nil
2020-07-22 12:35:00.678 Status: dzVents: Debug: openWeatherMap: OpenURL: headers = nil
2020-07-22 12:35:00.678 Status: dzVents: Debug: openWeatherMap: OpenURL: callback = openWeatherMap
2020-07-22 12:35:00.679 Status: dzVents: Info: openWeatherMap: ------ Finished Script #1
2020-07-22 12:35:00.680 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-07-22 12:35:03.328 Status: dzVents: Info: Handling httpResponse-events for: "openWeatherMap"
2020-07-22 12:35:03.328 Status: dzVents: Info: openWeatherMap: ------ Start internal script: Script #1: HTTPResponse: "openWeatherMap"
2020-07-22 12:35:03.441 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain today: Custom sensor device adapter
2020-07-22 12:35:03.444 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain 48 hours: Custom sensor device adapter
2020-07-22 12:35:03.446 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain 8 days: Custom sensor device adapter
2020-07-22 12:35:03.448 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for WeatherForecast: Text device
2020-07-22 12:35:03.451 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Current Temperature: Temperature device adapter
2020-07-22 12:35:03.453 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Max Temperature next 48 hours: Temperature device adapter
2020-07-22 12:35:03.456 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Min Temperature next 48 hours: Temperature device adapter
2020-07-22 12:35:03.458 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Max Temperature next 8 days: Temperature device adapter
2020-07-22 12:35:03.461 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Min Temperature next 8 days: Temperature device adapter
2020-07-22 12:35:03.461 Status: dzVents: Info: openWeatherMap: 1h
2020-07-22 12:35:03.462 Status: dzVents: Info: openWeatherMap: 1h
2020-07-22 12:35:03.462 Status: dzVents: Info: openWeatherMap: ------ Finished Script #1
2020-07-22 12:35:03.462 Status: dzVents: Info: openWeatherMap: ------ Start internal script: Weersvoorspelling: HTTPResponse: "openWeatherMap"
2020-07-22 12:35:03.539 Status: dzVents: Info: openWeatherMap: 1h
2020-07-22 12:35:03.541 Status: dzVents: Info: openWeatherMap: ------ Finished Weersvoorspelling
2020-07-22 12:35:03.543 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-07-22 12:35:03.462 Error: dzVents: Error: (3.0.2) openWeatherMap: An error occurred when calling event handler Script #1
2020-07-22 12:35:03.462 Error: dzVents: Error: (3.0.2) openWeatherMap: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:88: attempt to index a nil value (field 'temperature')
Hopefully you know a solution. Thanks in advance!
regards
Jan
Posted: Wednesday 22 July 2020 13:54
by waaren
Jan Jansen wrote: Wednesday 22 July 2020 13:12 Thanks for sharing your nice script! I want to add the minimum temperatures but I get an error that I can't resolve myself.
Updated script with option to add virtual sensors for minimum temperature 48 hours and minimum temperature temp 8 days.
        Then create the devices you want
        history
        20200720 Start coding - shared on forum
        20200722 Added minimum temperature devices
return
        timer =
            'at *:17'
        devices =
        httpResponses =
            scriptVar
    logging =
            marker = scriptVar,
        local maxTemperature48Hours = dz.devices('Max Temperature next 48 hours') -- Optional virtual Temperature sensor
        local maxTemperature8Days = dz.devices('Max Temperature next 8 days') -- Optional virtual Temperature sensor
        local minTemperature48Hours = dz.devices('Min Temperature next 48 hours') -- Optional virtual Temperature sensor
        local minTemperature8Days = dz.devices('Min Temperature next 8 days') -- Optional virtual Temperature sensor
            local totalmm = 0
            return totalmm
        local function get8DaysMinMaxTemperature(t)
            local minTemperature = 100
                if record.temp.min < minTemperature then minTemperature = record.temp.min end
            return dz.utils.round(maxTemperature,1), dz.utils.round(minTemperature,1)
        local function get48HoursMinMaxTemperature(t)
                if record.temp < minTemperature then minTemperature = record.temp end
            return dz.utils.round(maxTemperature,1),dz.utils.round(minTemperature,1)
            local totalmm = 0
            return totalmm
            local totalmm = 0
            return totalmm
            rt.maxTemperature48Hours, rt.minTemperature48Hours  = get48HoursMinMaxTemperature(rt.hourly)
            rt.maxTemperature8Days, rt.minTemperature8Days = get8DaysMinMaxTemperature(rt.daily)
            text = text .. '48 hours:  ' .. t.rain48Hours .. ' mm, ' .. t.maxTemperature48Hours .. ' °C' .. '\n'
            text = text .. '8 days:    ' .. t.rain8Days .. ' mm, ' .. t.maxTemperature8Days .. ' °C' .. '\n'
            if dv == nil then
                return false
            if deviceExists(maxTemperature48Hours) then maxTemperature48Hours.updateTemperature(rt.maxTemperature48Hours) end
            if deviceExists(maxTemperature8Days) then maxTemperature8Days.updateTemperature(rt.maxTemperature8Days) end
            if deviceExists(minTemperature48Hours) then minTemperature48Hours.updateTemperature(rt.minTemperature48Hours) end
            if deviceExists(minTemperature8Days) then minTemperature8Days.updateTemperature(rt.minTemperature8Days) end
        -- main code
                updateDevices(rt)
            dz.openURL({
Posted: Wednesday 22 July 2020 22:01
by waaren
Updated version with optional average temperature sensors. Also include a warning in the comments
Please note that dzVents requires acces to domoticz at a sufficient level to retrieve the location settings
including the latititude and longitude. It can only get these if the Local Networks (nu username/password)
include 127.0.0.1 (and ::1 for systems using IPv6)
Also explained in the wiki
        Explained in the wiki at:  https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#Using_dzVents_with_Domoticz
        history
        20200722 Added average and minimum temperature devices
return
        timer =
            'at *:17'
        devices =
        httpResponses =
            scriptVar
    logging =
            marker = scriptVar,
        local avgTemperature48Hours = dz.devices('Average Temperature next 48 hours') -- Optional virtual Temperature sensor
        local avgTemperature8Days = dz.devices('Average Temperature next 8 days') -- Optional virtual Temperature sensor
        local DAY_SECONDS = 86400
            local totalmm = 0
            return totalmm
        local function getDayNightSeconds(t)
            t.daySeconds = t.sunset - t.sunrise
            t.nightSeconds= DAY_SECONDS - t.daySeconds
        local function get8DaysTemperatures(t)
            local avgTemperature, avgHelper = 0, 0
                getDayNightSeconds(record)
                avgTemperature = ( record.temp.day * record.daySeconds + record.temp.night * record.nightSeconds ) / DAY_SECONDS
                avgHelper = avgHelper + avgTemperature
            dz.log(avgTemperature)
            dz.log(avgHelper)
            dz.log(#t)
            avgTemperature = avgHelper / #t
            return dz.utils.round(maxTemperature,1), dz.utils.round(minTemperature,1), dz.utils.round(avgTemperature,1)
        local function get48HoursTemperatures(t)
            local avgHelper = 0
                avgHelper = avgHelper + record.temp
            return dz.utils.round(maxTemperature,1),dz.utils.round(minTemperature,1), dz.utils.round((avgHelper / #t),1)
            local totalmm = 0
            return totalmm
            local totalmm = 0
            return totalmm
            rt.maxTemperature48Hours, rt.minTemperature48Hours, rt.avgTemperature48Hours  = get48HoursTemperatures(rt.hourly)
            rt.maxTemperature8Days, rt.minTemperature8Days, rt.avgTemperature8Days = get8DaysTemperatures(rt.daily)
            rt.maxTemperature8Days = math.max(rt.maxTemperature48Hours, rt.maxTemperature8Days)
            rt.minTemperature8Days = math.min(rt.minTemperature48Hours, rt.minTemperature8Days)
            if dv == nil then
                return false
            if deviceExists(avgTemperature48Hours) then avgTemperature48Hours.updateTemperature(rt.avgTemperature48Hours) end
            if deviceExists(avgTemperature8Days) then avgTemperature8Days.updateTemperature(rt.avgTemperature8Days) end
        -- main code
                updateDevices(rt)
            dz.openURL({
Posted: Monday 27 July 2020 15:45
by Emerson
@ waaren,
Thanks for sharing your script I have setup the requirements in domoticz: user variable, long, lat etc and the script runs, if i don't create the any virtual devices the script completes without errors;
2020-07-27 14:24:00.307 Status: dzVents: Info: openWeatherMap: ------ Start external script: weather.lua:, trigger: at *:24
2020-07-27 14:24:00.309 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain today: Custom sensor device adapter
2020-07-27 14:24:00.309 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Rain 48 hours
2020-07-27 14:24:00.310 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Rain 8 days
2020-07-27 14:24:00.310 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: WeatherForecast
2020-07-27 14:24:00.310 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Current Temperature
2020-07-27 14:24:00.310 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Max Temperature next 48 hours
2020-07-27 14:24:00.310 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Max Temperature next 8 days
2020-07-27 14:24:00.311 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Min Temperature next 48 hours
2020-07-27 14:24:00.311 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Min Temperature next 8 days
2020-07-27 14:24:00.311 Status: dzVents: Debug: openWeatherMap: OpenURL: url = https://api.openweathermap.org/data/2.5/onecall?&units=metric&lat=51.62143342246289&lon=-0.7175364494323&appid=xxxxxxxxxxx
2020-07-27 14:24:00.311 Status: dzVents: Debug: openWeatherMap: OpenURL: method = GET
2020-07-27 14:24:00.311 Status: dzVents: Debug: openWeatherMap: OpenURL: post data = nil
2020-07-27 14:24:00.311 Status: dzVents: Debug: openWeatherMap: OpenURL: headers = nil
2020-07-27 14:24:00.311 Status: dzVents: Debug: openWeatherMap: OpenURL: callback = openWeatherMap
2020-07-27 14:24:00.311 Status: dzVents: Info: openWeatherMap: ------ Finished weather.lua
if i add a virtual device (it doesn't matter which one) in the case of the below it is a virtual custom device called "Rain today" the script errors;
2020-07-27 14:24:01.143 Status: dzVents: Info: openWeatherMap: ------ Start external script: weather.lua: HTTPResponse: "openWeatherMap"
2020-07-27 14:24:01.196 Status: dzVents: Debug: openWeatherMap: Processing device-adapter for Rain today: Custom sensor device adapter
2020-07-27 14:24:01.196 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Rain 48 hours
2020-07-27 14:24:01.196 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Rain 8 days
2020-07-27 14:24:01.197 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: WeatherForecast
2020-07-27 14:24:01.197 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Current Temperature
2020-07-27 14:24:01.197 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Max Temperature next 48 hours
2020-07-27 14:24:01.197 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Max Temperature next 8 days
2020-07-27 14:24:01.197 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Min Temperature next 48 hours
2020-07-27 14:24:01.198 Status: dzVents: Error (2.4.19): openWeatherMap: There is no device with that name or id: Min Temperature next 8 days
2020-07-27 14:24:01.198 Status: dzVents: Error (2.4.19): openWeatherMap: An error occured when calling event handler weather
2020-07-27 14:24:01.198 Status: dzVents: Error (2.4.19): openWeatherMap: /home/pi/domoticz/scripts/dzVents/scripts/weather.lua:137: attempt to call field 'deviceExists' (a nil value)
2020-07-27 14:24:01.198 Status: dzVents: Info: openWeatherMap: ------ Finished weather.lua
I am at a loss as to the problem
Emerson
Posted: Monday 27 July 2020 17:13
by waaren
Emerson wrote: Monday 27 July 2020 15:45 2020-07-27 14:24:01.198 Status: dzVents: Error (2.4.19): openWeatherMap: /home/pi/domoticz/scripts/dzVents/scripts/weather.lua:137: attempt to call field 'deviceExists' (a nil value)
The function deviceExists is not available in your version of dzVents. it was introduced in dzVents 2.4.28
You can find the dzVents - domoticz version relation here
Posted: Monday 27 July 2020 17:40
by Emerson
@ waaren,
Thanks for the quick reply, that solved that mystery, better update to latest stable them
Emerson
Posted: Thursday 06 August 2020 14:45
by spider85
waaren wrote: Wednesday 22 July 2020 22:01 Updated version with optional average temperature sensors. Also include a warning in the comments
        history
return
        timer =
            'at *:17'
        devices =
        httpResponses =
            scriptVar
    logging =
            marker = scriptVar,
            local totalmm = 0
            return totalmm
            dz.log(avgHelper)
            dz.log(#t)
            local avgHelper = 0
            local totalmm = 0
            return totalmm
            local totalmm = 0
            return totalmm
            if dv == nil then
                return false
        -- main code
                updateDevices(rt)
            dz.openURL({
Hi Waaren,
How and where do i need to put the APi and lat long?
Posted: Thursday 06 August 2020 15:10
by waaren
spider85 wrote: Thursday 06 August 2020 14:45 How and where do i need to put the APi and lat long?
the API key goes here
and the lat long goes here
Posted: Thursday 06 August 2020 16:37
by kiddigital
There is a Pull Request on Github (https://github.com/domoticz/domoticz/pull/4284) for a big update of the OpenWeatherMap module in Domoticz which also includes the 8 day weather forecast as separate sensors including min and max temperature, probability of precipitation (rain, drizzle, snow, etc), etc.
If/once this Pull Request is merged into the beta, it can be tested to see if it has enough possibilities to control things like garden sprinklers, etc.
Posted: Thursday 06 August 2020 19:36
by spider85
waaren wrote: Thursday 06 August 2020 15:10
Tnx, got it working, is it possible to get the max temp for 24h (for the next day)?
If it is possible i could make a timing thing for my garden sprinklers.
