Yesterday I received some doorsensors and started to integrate them in my domoticz system. These are EV1527 devices,sending 433mhz signal. Rflink recognized them as soon as they were used and within domoticz 2 devices were created automaticly (one for open one for close). the last time used was updated.
After that when I use the sensor (open or close the door) nothing happens in Domoticz. I started investigating and found out the data of the device is coming in on the serial port of the Rflink device.
20;20;EV1527;ID=XXXXXX;SWITCH=03;CMD=ON;
20;1C;EV1527;ID=xxxxxx;SWITCH=03;CMD=ON;
20;1D;DEBUG;Pulses=50;Pulses(uSec)=390,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,1140,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1140,330,300,6990;
20;1E;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;1F;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1140,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;20;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;21;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1140,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;22;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;23;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,1140,300,300,6990;
20;24;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1140,330,300,6990;
20;25;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;26;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1140,300,1110,300,1140,300,300,1140,1140,300,1140,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;27;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1140,300,1110,300,300,1140,1110,300,1140,300,1110,300,1140,300,300,1140,1110,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1140,330,300,6990;
20;28;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;29;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;2A;DEBUG;Pulses=48;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,6990;
20;2B;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;2C;EV1527;ID=xxxxxx;SWITCH=09;CMD=ON;
20;2D;DEBUG;Pulses=50;Pulses(uSec)=390,1140,1110,300,1140,300,1140,300,300,1140,1110,300,1110,300,1140,300,1140,300,300,1140,1110,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;2E;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1140,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;2F;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;30;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;31;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;32;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,300,1140,300,1140,1140,300,300,6990;
20;33;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;34;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;35;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;36;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1110,1140,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;37;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1140,300,1110,300,300,1140,300,1110,300,1140,300,1140,300,1140,300,1140,300,1110,1140,300,300,1140,300,1140,1140,330,300,6990;
20;38;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1110,300,1140,1110,330,300,6990;
20;39;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1110,1110,300,1110,300,1110,300,300,1140,300,1110,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,300,1110,300,1140,1110,330,300,6990;
20;3A;DEBUG;Pulses=48;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1110,300,1140,1140,6990;
20;3B;DEBUG;Pulses=30;Pulses(uSec)=1170,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;3C;DEBUG;Pulses=34;Pulses(uSec)=450,300,270,1080,1080,270,1080,270,1080,270,270,1080,270,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;3D;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;3E;EV1527;ID=xxxxxx;SWITCH=03;CMD=ON;
20;3F;DEBUG;Pulses=50;Pulses(uSec)=390,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;40;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;41;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;42;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;43;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;44;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,1140,330,300,6990;
20;45;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,1110,330,300,6990;
20;46;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1140,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1110,330,300,6990;
20;47;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;48;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,1140,330,300,6990;
20;49;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1140,330,300,6990;
20;4A;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1140,300,1110,300,300,1140,1140,300,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,1110,330,300,6990;
20;4B;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;4C;EV1527;ID=xxxxxx;SWITCH=09;CMD=ON;
20;4D;DEBUG;Pulses=50;Pulses(uSec)=390,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;4E;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;4F;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,300,1140,300,1140,1140,300,300,6990;
20;50;DEBUG;Pulses=50;Pulses(uSec)=390,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1110,1140,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1110,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;51;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;52;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1110,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1110,300,1140,1110,330,300,6990;
20;53;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1140,300,1140,300,300,1140,1140,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;54;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1140,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1110,1140,330,300,6990;
20;55;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1140,330,300,6990;
20;56;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1140,300,300,1140,1140,300,1110,300,1110,300,1110,300,300,1140,1140,300,1140,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1140,330,300,6990;
20;57;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1110,300,1110,300,1140,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1140,300,300,1140,300,1140,1110,330,300,6990;
20;58;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1140,300,1110,300,1110,300,300,1140,1140,300,1110,300,1110,300,1140,300,300,1140,1140,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;59;DEBUG;Pulses=50;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1140,300,300,1140,1140,300,1140,300,1110,300,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,300,1140,1110,300,300,1140,300,1140,1110,330,300,6990;
20;5A;DEBUG;Pulses=48;Pulses(uSec)=360,1140,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,1110,300,300,1140,1110,300,1110,300,1110,300,300,1110,300,1140,300,1140,300,1140,300,1140,300,1110,300,1140,1110,300,300,1140,300,1140,1110,6990;Anybody an idea how to solve this?
