Sunscreen script
Posted: Monday 13 July 2020 11:03
by Rupserdub
-- Define all the sensors which needs to be considered for the sunscreen to close
local sensors = {
    temperature = {
        active = true,
        device = 'Feel Temperature',
        closeRule = function(device)
            return device.temperature <= 14
    wind = {
        active = true,
        device = 'Wind',
            return  device.speed >= 50 or device.gust >= 300
    rain = {
        active = false,
        device = 'Rain Intensity',
            return  device.rainRate < 0
    rainExpected = {
        active = true,
        device = 'Rain Intensity', -- This needs to be a virtual sensor of type 'percentage'
            return  device.percentage > 0
    uv = {
        active = false,
        device = 'Zonnepanelen',
            return device.usage <= 250.000
    Zonnepanelen = {
        active = true,
        device = 'Zonnepanelen Rasp',
            return  device.usage  <= 150.000
-- Define the name of your sunscreen device
local sunscreenDevice = 'Zonnescherm'
-- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
local dryRun = false
-- Define the name of a virtual switch which you can use to disable the sunscreen automation script
-- Set to false to disable this feature
local manualOverrideSwitch = false
-- Minutes to wait after a sunscreen close before opening it again.
local timeBetweenOpens = 2
    active = true,
        timer = {'every minute'}
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = 'Zonnescherm'
    execute = function(domoticz)
        local function switchOn(sunscreen, message)
            if (sunscreen.state == 'Closed') then
                if (not dryRun) then
                    sunscreen.switchOn()
                    domoticz.notify('Zonnescherm', message)
                domoticz.log(message, domoticz.LOG_INFO)
        local function switchOff(sunscreen, message)
            if (sunscreen.state == 'Open') then
                    sunscreen.switchOff()
        if (manualOverrideSwitch and domoticz.devices(manualOverrideSwitch).state == 'On') then
            domoticz.log('Automatic sunscreen script is manually disabled', domoticz.LOG_DEBUG)
            return
        local sunscreen = domoticz.devices(sunscreenDevice)
        -- Sunscreen must always be up during nighttime
        if (domoticz.time.isNightTime) then
            switchOff(sunscreen, 'Closing sunscreen, It is night')
            return
        -- Check all sensor tresholds and if any exeeded close sunscreen
        for sensorType, sensor in pairs(sensors) do
            if (sensor['active'] == true) then
                local device = domoticz.devices(sensor['device'])
                local closeRule = sensor['closeRule']
                domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_DEBUG)
                if (closeRule(device)) then
                    switchOff(sunscreen, sensorType .. ' treshold exceeded, Sunscreen up')
                    domoticz.log(sensorType .. ' treshold exceeded', domoticz.LOG_DEBUG)
                    -- Return early when we exeed any tresholds
                    return
                domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_DEBUG)
        -- All tresholds OK, sunscreen may be lowered
        if (sunscreen.lastUpdate.minutesAgo > timeBetweenOpens) then
            switchOn(sunscreen, 'Sun is shining, all thresholds OK, lowering sunscreen')
So i'm working on a script that makes the screen go up when bad weather is coming and that part works, but the problem is that the screen is suppose to work with our solar panels. The part at 'zonnepanelen' is not working properly due to the .usage i'm guessing.
can anyone help me with this?
Re: Sunscreen script
Posted: Monday 13 July 2020 12:06
by waaren
Rupserdub wrote: Monday 13 July 2020 11:03 So i'm working on a script that makes the screen go up when bad weather is coming and that part works, but the problem is that the screen is suppose to work with our solar panels. The part at 'zonnepanelen' is not working properly due to the .usage i'm guessing.
I added a log statement. It will show you the value of the zonnepanelen.usage
    active = true,
    logging = {
local sensors = {
    temperature = {
        active = true,
    wind = {
        active = true,
        device = 'Wind',
    rain = {
        active = false,
    rainExpected = {
        active = true,
    uv = {
        active = false,
    Zonnepanelen = {
        active = true,
			domoticz.log('Zonnepanelen usage ' .. tostring(device.usage), domoticz.LOG_DEBUG)
            return
            return
                    return
Posted: Monday 27 July 2020 16:36
by Jan Jansen
I'am playing around with this script, but I run into a problem. OMW does not generate a gust value. I retrieve this value via NodeRed from Buienradar and make it a user variable. I adapted the script to that (I guess?). In the log I see an error that I cannot fix myself. What is wrong?
Script Sun screen.png (6.92 KiB) Viewed 2610 times
Thanks in advance!
Posted: Monday 27 July 2020 16:56
by waaren
Jan Jansen wrote: Monday 27 July 2020 16:36 I'am playing around with this script, but I run into a problem. OMW does not generate a gust value. I retrieve this value via NodeRed from Buienradar and make it a user variable. I adapted the script to that (I guess?). In the log I see an error that I cannot fix myself. What is wrong?
If you post a script issue then please share your complete code and log within code tags </>.
If you need the value of a uservariable you should use something like domoticz.variables('varName').value
Posted: Friday 07 January 2022 14:08
by pgas37
I am using the script, added some features, all works fine accept for one thing:
Windvlaag_Ri = {
active = true,
device = 'Wind BR',
return (device.direction >= 60 or device.direction <= 247) and (device.gust >= 13.9) -
see script
I want the Wind closeRule be active only if the wind is coming from a direction between 60 and 247degrees. That works fine with the 'or' function:
return (device.direction >= 60 or device.direction <= 247) but
if add e.g. the device.gust,
return (device.direction >= 60 or device.direction <= 247 and device.gust >= 10.8) it does not work.
return (device.direction >= 60 or device.direction <= 247 or device.gust >= 10.8), is a accepted so "return" only accept 1 value. In this case >=60 or <=247 or >=10.8.
I did a lot of experiments in the script but i can not get it to work the way i want (winddirection and gust or winddirection and speed)
Is there a workaround to solve this?
thanks for the help
Paul
-- werkt samen met script LuxTemp (gemiddelde lux meting)
local sensors = {
    temperature = {
        active = true,
        device = 'Temp/hum ms',
            return device.temperature <= 10 --15
    WindSnelheid_Ri = {
        active = false,
        device = 'Wind BR',
            return (device.direction >= 60 or device.direction <= 247 and device.speed >= 10.8)          -- =Bft 6. in m/s. 5 bft= 8..10.7m/s.  6bft= 10.8..13.8 m/s
    Windvlaag_Ri = {
        active = true,
        device = 'Wind BR',
    rain = {
        active = true,
        device = 'Rain BR',
            return device.rainRate > 0
    rainExpected = {
        active = true,
        device = 'Possible Rain BR', -- This needs to be a virtual sensor of type 'percentage'
            return device.state == 'On'
    --[[    return device.percentage > 15 --]]
     uv = {
        active = true,
        device = 'Ultraviolet',
            return device.uv <= 3
    lux = {
        active = true,
        device = 'Illuminance',
            return device.lux <= 2000
    lux = {
        active = true,
        device = 'Lux dummy gem 30min',                             -- device is gedefinieerd in script 'LuxTemp average'
           -- local startmoment = device.lux                          -- toegevoegd
            --print('=== startmoment average 30min:'..startmoment)
            return device.lux <= 300        --3000                            -- Lux_30min_switch staat op 3100Lux
local sunscreenDevice = 'sunscreenblinds'
local manualOverrideSwitch = 'manualOverrideBlinds'
--local manualOverrideSwitch = true           --false
local timeBetweenOpens = 0 --10
    active = true,
    logging = {
        -- uncomment level en marker om debugging aan te zetten
        --level = domoticz.LOG_DEBUG,
        --marker = 'Sunscreenmarker='
                    domoticz.notify('Sunscreen= 1', message)
                    domoticz.notify('Sunscreen= 2', message)
-- Locals voor Alarm tekstmeldingen-------------------------------------------------------------------------------
domoticz.log ("=Graden=Gusts=Speed=======================================",  domoticz.LOG_DEBUG)
--local graden = domoticz.devices('Wind BR').direction
local graden = 180
domoticz.log ('=Graden===================' ..graden, domoticz.LOG_DEBUG)
local richting = domoticz.devices('Wind BR').directionString
domoticz.log('=windrichting=========' ..richting, domoticz.LOG_DEBUG)
--local Wvlaag = domoticz.devices('Wind BR').gust
local Wvlaag = 14
domoticz.log ("=Windvlaag================" ..Wvlaag, domoticz.LOG_DEBUG)
--local Wsnelh = domoticz.devices('Wind BR').speed
local Wsnelh = 8
domoticz.log ("=Windsnelheid============" ..Wsnelh, domoticz.LOG_DEBUG)
local Ws_niet_afgerond = Wsnelh       --domoticz.devices('Wind BR').speed
local Ws_afgerond = math.floor((Ws_niet_afgerond) * 10)/10       --math.floor((Ws_niet_afgerond + 0.05) * 10)/10
domoticz.log ("=Windsnelheid===afgerond=========" ..Ws_afgerond, domoticz.LOG_DEBUG)
domoticz.log ('=Graden===' ..graden .. ' , Windvlaag: '..Wvlaag .. ', Windsnelheid : ' ..Ws_afgerond, domoticz.LOG_DEBUG)
local Regen = ''
    if domoticz.devices('Is it Raining').state == 'On' then
        Regen = 'Het regent in Bergen'
        Regen = 'Geen regen in Bergen'
        domoticz.log ('=Regen: ' ..Regen, domoticz.LOG_DEBUG)
local lum1 = domoticz.devices('Lux dummy gem 30min').lux
domoticz.log(' lumen======:' ..lum1, domoticz.LOG_DEBUG)
-- uitschakelen van de manualOverrideSwitch bij sunrise nadat isNightTime is afgelopen
        local T1 = (domoticz.time.secondsSinceMidnight/60)
        local T2 = (domoticz.time.sunriseInMinutes)
         domoticz.log ("minuten  na middernacht=================" ..T1, domoticz.LOG_DEBUG)
         domoticz.log ("Sunrise in minuten na middernacht=======" ..T2, domoticz.LOG_DEBUG)
            if T2 == T1 then
             domoticz.devices(manualOverrideSwitch).switchOff()
        if (domoticz.devices(manualOverrideSwitch).state == 'On') then              --manualOverrideSwitch and
            return
                local txt =  ('ManualOverrideSwitch = On.<br> Screens up.<br>Nighttime')
                domoticz.devices('Alarm Wind').updateAlertSensor(1,txt)
            domoticz.devices(manualOverrideSwitch).switchOn()
            domoticz.devices('Lux_30min_switch').switchOn()
           return
-- -----omrekening windsnelheid m/s naar beaufort en knopen-----------------------------------------------------
local Bft = 0
local Kn = 0
         --domoticz.log ('=Beaufort========== :' ..Bft, domoticz.LOG_DEBUG)
    if  Ws_afgerond >= 24.5 and Ws_afgerond <= 28.4 then Bft = 10  Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
        domoticz.log ('=Knopen========== :' ..Kn, domoticz.LOG_DEBUG)
    if  Ws_afgerond >= 20.8 and Ws_afgerond <= 24.4 then Bft = 9 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
   if  Ws_afgerond >= 17.2 and Ws_afgerond <= 20.7 then Bft = 8 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
    if Ws_afgerond >= 13.9 and Ws_afgerond <= 17.1 then Bft = 7 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
    if  Ws_afgerond >= 10.8 and Ws_afgerond <= 13.8 then Bft = 6 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
       if  Ws_afgerond >= 8.0 and Ws_afgerond <= 10.7 then Bft =  5 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)   --5 Kn = (Ws_afgerond * 1.944)
    if  Ws_afgerond >= 5.5 and Ws_afgerond <= 7.9 then Bft = 4 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
    if  Ws_afgerond >= 3.4 and Ws_afgerond <= 5.4 then Bft = 3 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
    if  Ws_afgerond >= 1.6 and Ws_afgerond <= 3.3 then Bft = 2 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
    if  Ws_afgerond >= 0.3 and Ws_afgerond <= 1.5 then Bft = 1 Kn = math.floor((Ws_afgerond * 1.944) * 10/10)
-- -------omrekening windvlagen m/s naar beaufort en knopen--------------------------------
local Bftvl = 0
local Kn_vl  = 0
         --domoticz.log ('=Beaufort windvlaag========== :' ..Bftvl, domoticz.LOG_DEBUG)
    if  Wvlaag >= 24.5 and Wvlaag <= 28.4 then Bftvl = 10 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
        domoticz.log ('=Beaufort windvlaag========== :' ..Bft, domoticz.LOG_DEBUG)
        domoticz.log ('=Knopen windvlaag========== :' ..Kn_vl, domoticz.LOG_DEBUG)
    if  Wvlaag >= 20.8 and Wvlaag <= 24.4 then Bftvl = 9 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
        domoticz.log ('=Beaufort windvlaag==========' ..Bftvl, domoticz.LOG_DEBUG)
   if  Wvlaag >= 17.2 and Wvlaag <= 20.7 then Bftvl = 8 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
    if Wvlaag >= 13.9 and Wvlaag <= 17.1 then Bftvl = 7 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
    if  Wvlaag >= 10.8 and Wvlaag <= 13.8 then Bftvl = 6 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
       if  Wvlaag >= 8.0 and Wvlaag <= 10.7 then Bftvl = 5 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
    if  Wvlaag >= 5.5 and Wvlaag <= 7.9 then Bftvl = 4 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
        domoticz.log ('==Beaufort windvlaag==========' ..Bftvl, domoticz.LOG_DEBUG)
    if  Wvlaag >= 3.4 and Wvlaag <= 5.4 then Bftvl = 3 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
    if  Wvlaag >= 1.6 and Wvlaag <= 3.3 then Bftvl = 2 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
    if  Wvlaag >= 0.3 and Wvlaag <= 1.5 then Bftvl = 1 Kn_vl = math.floor((Wvlaag * 1.944) * 10/10)
-- ---Wind Alarm sensor--text feed-----------------------------------------------------
    -- oorspronkelijke txt string. Vond ik lang en onoverzichtelijk. aangepast hieronder
    if (graden >= 60 and graden <= 247) and (Ws_afgerond <= 10.7 or Wvlaag <= 13.9) then
                local txt =  ('<FONT COLOR=red><u>1 Windrichting waarschuwing.</u></FONT><br><br><br><br><br><FONT COLOR=grey>Wrichting tussen (>60..<247): ' ..graden.. 'gr. ' ..richting..'</FONT><br>Wsnelheid niet >10.7m/s: ' ..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft:' ..Bft.. '<br> Wvlaag niet >13.9m/s:.....'..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'.  Bftvl:' ..Bftvl.. '<br>' ..Regen)
                domoticz.devices('Alarm Wind').updateAlertSensor(0,txt)         -- 0= grey, 2= yellow
                --local txt =  ('<FONT COLOR=blue>Geen wind waarschuwing voor sunblinds.</FONT><br><br> Wrichting (>60..<247): ' ..graden.. 'gr. ' .. richting..'<br> Wsnelheid >10.7: ' ..Ws_afgerond .. 'm/s.  Kn: '..Kn..'.  Bft :' ..Bft.. '<br> Wvlaag >13.9: '..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl:' ..Bftvl..'<br>' ..Regen)
                local txt1 = ('<FONT COLOR=blue>Geen wind waarschuwing voor sunblinds.</FONT><br><br><br><br><br>')
                local txt2 = ('<FONT COLOR=green>Wrichting (>60..<247): ' ..graden.. 'gr. ' .. richting..'<br></FONT>')
                local txt3 = ('Wsnelheid >10.7: ' ..Ws_afgerond .. 'm/s.  Kn: '..Kn..'.  Bft :' ..Bft.. '<br>')
                local txt4 = ('Wvlaag >13.9: '..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl:' ..Bftvl.. '<br>')
                local txt5 = (''..Regen)
                domoticz.devices('Alarm Wind').updateAlertSensor(1,txt1 ..txt2 ..txt3 ..txt4 ..txt5)         -- 1= green
     if     (graden >= 60 and graden <= 247) and (Ws_afgerond >= 10.7) then
                --local txt =  ('<FONT COLOR=red> <u>2 WAARSCHUWING windrichting en snelheid.</u> <br><br>Wrichting tussen (>60..<247): ' ..graden.. 'gr.  ' ..richting..'<br>Wsnelheid >10.7m/s: ' ..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft :' ..Bft..'.<br><FONT COLOR=black> Wvlaag < 13.9:.....'..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl :' ..Bftvl.. '</FONT><br>' ..Regen)
                local txt1 = ('<FONT COLOR=red> <u>2 WAARSCHUWING windrichting en snelheid.</u>')
                local txt2 = ('<br><br><br><br><br>Wrichting tussen (>60..<247): ' ..graden.. 'gr.  ' ..richting..'<br>')
                local txt3 = ('Wsnelheid >10.7m/s: ' ..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft :' ..Bft..'.<br>')
                local txt4 = ('<FONT COLOR=black> Wvlaag < 13.9:.....'..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl :' ..Bftvl.. '</FONT>')
                local txt5 = ('<br>' ..Regen)
                domoticz.devices('Alarm Wind').updateAlertSensor(4,txt1 ..txt2 ..txt3 ..txt4 ..txt5)     --4-red
    if     (graden >= 60 and graden <= 247) and (Wvlaag >= 13.9) then
                --local txt =  ('<FONT COLOR=red> <u>3 WAARSCHUWING Windrichting en -vlaag.</u><br> Windrichting tussen (>60..<247): ' ..graden.. 'gr. ' ..richting..'<br> </FONT> <FONT COLOR=black> Windsnelheid <10.7: ' ..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft :' ..Bft.. '.<br><FONT COLOR=red> Windvlaag > 13.9:.....'..Wvlaag .. 'm/s.  Kn_vl:' ..Kn_vl..'. Bftvl :' ..Bftvl.. '</FONT><br>' ..Regen)
                local txt1 = ('<FONT COLOR=red> <u>3 WAARSCHUWING Windrichting en -vlaag.</u><br><br><br><br><br> ')
                local txt2 = ('Windrichting tussen (>60..<247): ' ..graden.. 'gr. ' ..richting..'<br> </FONT>')
                local txt3 = ('<FONT COLOR=black> Windsnelheid <10.7: '..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft :' ..Bft..'<br>')
                local txt4 = ('<FONT COLOR=red> Windvlaag ......>13.9: '..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl :' ..Bftvl..'</FONT>')
                --local resultString = txt1 ..txt2 ..txt3 ..txt4 ..txt5     -- mogelijkheid om txtStrings te combineren
    if     (graden >= 60 and graden <= 247) and (Ws_afgerond >= 10.7 and Wvlaag >13.9) then
                --local txt =  ('<FONT COLOR=red><b> 4 WAARSCHUWING.</u><br>Wrichting tussen (>60..<247): ' ..graden.. 'gr. = ' ..richting..'<br> Wsnelheid >10.7m/s: ' ..Ws_afgerond .. 'm/s. Kn:'..Kn..' Bft:' ..Bft.. '<br> Wvlaag >13.9m/s: .....'..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..' Bftvl: ' ..Bftvl.. '<br></FONT>' ..Regen)
                --    domoticz.devices('Alarm Wind').updateAlertSensor(4,txt)     --4-red
                local txt1 = ('<FONT COLOR=red> <u>4 WAARSCHUWING.</u><br><br><br><br><br>')
                local txt2 = ('Windrichting tussen (>60..<247): ' ..graden.. 'gr. ' ..richting..'<br>')
                local txt3 = ('Windsnelheid <10.7: '..Ws_afgerond .. 'm/s. Kn:'..Kn..'.  Bft :' ..Bft..'<br>')
                local txt4 = ('Windvlaag ......>13.9: '..Wvlaag .. 'm/s. Kn_vl:' ..Kn_vl..'. Bftvl :' ..Bftvl..'</FONT>')
if (graden >= 60 and graden <= 247) and (Ws_afgerond >= 10.7 or Wvlaag >= 13.9) then
   domoticz.notify('Wind Alarm',' WindR, -snelh en -vlaag limieten overschreden.  Gr: ' ..graden .. ' , Windvlg: '..Wvlaag .. ',  Windsn : ' ..Ws_afgerond,domoticz.PRIORITY_NORMAL,domoticz.SOUND_SPACEALARM,nil,domoticz.NSS_PUSHOVER)
 -- activering van het script indien device 'Lux dummy gem 30min' eenmalig boven de grenswaardelux is geweest
        local Luxgrenswaarde = 3100 --3100
        local Lux_startmoment = domoticz.devices('Lux dummy gem 30min').lux
            domoticz.log('Startmoment average 30min: Lux '..Lux_startmoment, domoticz.LOG_DEBUG)
        if Lux_startmoment < Luxgrenswaarde and domoticz.devices('Lux_30min_switch').state == 'On' then                   -- switch wordt Off gezet nadat het 30min gemiddelde is overschreden waardoor script locals actief kunnen worden
            domoticz.log('Luxgrenswaarde '..Luxgrenswaarde .. 'Lux niet overschreden. Return', domoticz.LOG_DEBUG)
            return
            domoticz.devices('Lux_30min_switch').switchOff().checkFirst()
             -- toegevoegd om de reden van open en dicht vast te leggen
                txtSBlog = (sensorType.. '  treshold exceeded')
                domoticz.log('==txtSBlog====:  ' .. txtSBlog, domoticz.LOG_DEBUG)
                domoticz.devices('Log open_dicht sunblinds').updateText(txtSBlog)
                    return
Posted: Monday 01 July 2024 19:57
by madpatrick
Hi Guys,
I've modified the script for my needs, but the problem is when it has triggered 1 treshold the script stops.
I like to check all sensors and switch those at the treshold until it has checked all sensors.
This is was i have made until now
local scriptVar             = '-=# TEST sunscreens #=-'
    active = true,
        timer = {'every 5 minutes at 07:00 - 21:00'},
        devices = {727,728,290},
    logging = {
                state = domoticz.LOG_ERROR,
                marker      = scriptVar
local sensors = {
    Screen_Erker1 = {
        active = true,
        device = 607,
            return device.level < 99
    Screen_Erker2 = {
        active = true,
        device = 610,
    Screen_Erker3 = {
        active = true,
        device = 606,
    Screen_Erker4 = {
        active = true,
        device = 609,
    Screen_Erker5 = {
        active = true,
        device = 611,
            return device.level > 99
    Screen_Wnk_gr = {
        active = true,
        device = 493,
    Screen_Wnk_kl = {
        active = true,
        device = 612,
    Screen_Deur = {
        active = true,
        device = 605,
    Screen_Thomas_1 = {
        active = true,
        device = 604,
    Screen_Thomas_2 = {
        active = true,
        device = 608,
    Screen_Slaapkamer = {
        active = true,
        device = 613,
local RegenData     = domoticz.devices(445)
local MowerState            = domoticz.devices(727)
local MowerRun              = domoticz.devices(728)
local MowerAction           = domoticz.devices(730)
    if (RegenData.rainRate > 0) and (MowerRun.level == 'On') then
        MowerAction.setLevel(50)
        dz.log('Regen : ' .. dz.utils.round(RegenData.rainRate,2) .. ' mm', dz.LOG_FORCE)
        dz.log('Regen : Mower gaat naar huis', dz.LOG_FORCE)
            if (sensor['active'] == true) and (RegenData.rainRate > 0) then
                domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_FORCE)
                    device.switchOn()
                    domoticz.log(sensorType .. ' treshold exceeded', domoticz.LOG_FORCE)
                    return
                domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_FORCE)
Thanks !!
