Hello everyone,
I have a Tasmota running in one ESP8266 connected with a 3 channel RGB, and working well:
http://prntscr.com/tfngi9
Now I am trying to add this ESP with a RGB Led Strip to Domoticz, but till now, I am only able to turn it ON and OFF.
I have setup a Dummy Hardware for this Esp Led RGB Strip 1, and created a Virtual Sensor, with a sensor type of RGB Switch, resulting in this entrie:
http://prntscr.com/tfnhgs
Now the thing is that I cannot choose any color or even the intensity, only ON and OFF, with last color and intensity set in Tasmota.
From Tasmosta side, I have this under Domoticz Parameters:
http://prntscr.com/tfnj9v
And from MQTT:
http://prntscr.com/tfnjj4
From Tasmosta console there is nothing when I change color and intensity.
Anyone knows want its missing?
Versions:
Tasmosta 8.3.1
Domoticz 3.8153
Tasmota under ESP8266 with 3 channel RGB in Domoticz
marafado88
marafado88
Re: Tasmota under ESP8266 with 3 channel RGB in Domoticz
From Tasmota side I have in logs:
For the first line, is the way it sents ON and OFF, and the rest is when colors and intensities are set,but there is no parameters being sent from what I see here.
Anyone knows?
2020-07-11 00:42:42.805 User: Admin initiated a switch command (32/Esp Led RGB Strip 1/On)
2020-07-11 00:42:42.806 (Esp Led RGB Strip 1) Lighting Limitless/Applamp (Esp Led RGB Strip 1)
2020-07-11 00:42:46.669 (Esp Led RGB Strip 1) Lighting Limitless/Applamp (Esp Led RGB Strip 1)
2020-07-11 00:42:46.771 (Esp Led RGB Strip 1) Lighting Limitless/Applamp (Esp Led RGB Strip 1)
2020-07-11 00:42:47.381 (Esp Led RGB Strip 1) Lighting Limitless/Applamp (Esp Led RGB Strip 1)
2020-07-11 00:42:47.483 (Esp Led RGB Strip 1) Lighting Limitless/Applamp (Esp Led RGB Strip 1)Anyone knows?
riccardom67
Hi I am new in the Forum.
Can you provide me how do you connect the strip led to ESP8266 using Tasmota ?
Do you use a Transistor Darlington ?
RIccardo
RIccardo
