z-wave and node-red and mqtt Topic is solved
steing
Domoticz version: 4.11665
Post by steing »
I use node-red and MQTT to communicate between Tellstick Duo and Domoticz.
Now, I was hoping that I could also use node-red to have MQTT send commands to and receive info from the z-wave devices in Domoticz.
However, if I use the open-zwave nodes in node-red, nothing works. It seems as if both Domoticz and node-red fights over the z-wave controller.
Is it at all possible to have node-red and Domoticz simultaneously communicating with the same z-wave device?
echo 659129659305049656388224222264957751972462554378P | dc
FireWizard
Re: z-wave and node-red and mqtt
Post by FireWizard »
Did you enable loop-back?
See this post: https://www.domoticz.com/forum/viewtopi ... t&start=20
Solution is in the post of April 8, 2020
steing
Post by steing »
Oh.
I think I got it.
I dont need the zwave nodes in node in node-red. Only the mqtt nodes. And then an mqtt-node in domoticz.
thanks!
