Hi!
i have a google nest hello doorbell and i wonder if its possible to get this camera into Domoticz?
i notived that there is a Domoticz-NEST-plugin, could i use this plugin to get it to work?
it would also be nice if it would be possible to get a notification in domotica when the button is pusched on the doorbell.
best regards
mark.sellwood
Re: google nest hello doorbell
The Google Hello Doorbell is not supported by any of the plugins.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
tjabas
ok, that sucks, do you think that its possible to add it as a camera?
- epierre
It could be supported if the mydomoticz website could forward oauth requests as home assistant does:
https://www.home-assistant.io/integrations/nest/
"Add Authorized redirect URIs end enter https://my.home-assistant.io/redirect/oauth"
When we have this, it will be quick to do something I think.
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
