Installing Domoticz server on Android
mishamdavan
Post by mishamdavan »
I have recently installed mosquitto and homeassistant onto my galaxy tab2, which works well using Termux.
My question is, can I do the same with Domoticz and if so, how?
Cheers,
AnthonyColson
Re: Installing Domoticz server on Android
Post by AnthonyColson »
I wanna try this on my Android also.
MartHale
Post by MartHale »
I also want to try this, the price of raspberry pi's have gone thru the roof, and I was looking for alternative devices to be my server.
Now I am wondering if perhaps another micro computer may be a better way to go for running Domoticz.
Perhaps a Chrorme book or an tablet ?
I am curious what devices are proven to work.... besides PC, Raspberry Pi.
pvoj
Domoticz version: 3.5964
Post by pvoj »
I know it is an old question. :)
You can run domoticz on Android quite easily.
First install Termux. Termux is not suitable to run Docker. First you need to install QEMU and on top of that you can install a Linux distribution. Alpine is quite small to do this. And with this you will be in the finish line. You can install Docker and run a domoticz container.
derrij
Post by derrij »
in Termux:
pkg install proot-distro -y
proot-distro install debian
proot-distro login debian
apt update
mkdir ~/domoticz
cd ~/domoticz
wget https://releases.domoticz.com/releases/release/domoticz_linux_aarch64.tgz
tar -xf  domoticz_linux_aarch64.tgz
 apt install sqlite3 -y
 apt install  curl unzip wget sudo cron libudev-dev libcurl4-gnutls-dev libpython3-dev -y
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb11u5_arm64.deb
dpkg -i  libssl1.1_1.1.1n-0+deb11u5_arm64.deb
wget http://ftp.de.debian.org/debian/pool/main/libu/libusb/libusb-0.1-4_0.1.12-32_arm64.deb
dpkg -i libusb-0.1-4_0.1.12-32_arm64.deb
./domoticz
