[Solved] LUA script with beacon key + Security Panel
McJohn
Post by McJohn »
We struggle with the script below. It won't "fire".
The script is working well without the text "and (otherdevices['Domoticz Security Panel'] == 'Disarmed')) then"
But what we want is that it only works when the Security Panel is "Disarmed" or when it is "Arm Away"
What have we done wrong?
Thanks in advance for the support.
 if ((devicechanged['Beacon key'] == 'Off') and (otherdevices['Domoticz Security Panel'] == 'Disarm')) then
    commandArray['Domoticz Security Panel'] = 'Arm Away'
    commandArray['Variable:Security'] = 'On'
 if ((devicechanged['Beacon key'] == 'On') and (otherdevices['Domoticz Security Panel'] == 'Arm Away')) then
    commandArray['Domoticz Security Panel'] = 'Disarm'
    commandArray['Variable:Security']= 'Off'
jvdz
Domoticz version: 4.107
Re: LUA script with beacon key + Security Panel
Post by jvdz »
You are testing for the wrong value. They should be one of these:
globalvariables['Security'] = 'Disarmed'    -- or  'Armed Home' or 'Armed Away'
So guess this should do it:
 if ((devicechanged['Beacon key'] == 'Off') and (globalvariables['Security'] == 'Disarmed')) then
 if ((devicechanged['Beacon key'] == 'On') and (globalvariables['Security'] == 'Armed Away')) then
Jos :D
McJohn
Post by McJohn »
Jos! Friend!
Thank you so much for the quick reply.
It's working, fast and smooth!
(I saw you are the expert in this field, sorry for the simple question but sometimes the Domoticz Security Panel is a "device" and sometimes a variable).
All the best
John :)
