Ev1527 Chinese devices
Posted: Monday 22 June 2020 22:43
by xavierlp
Hello all
I’m looking for information about integration of EV1527 switches.
I found theses switches and I’d like if one of you could integrate it.
https://a.aliexpress.com/_BUrO9m
I could read some information and it could be possible but in some cases not !!!!
Any feedbacks or advices ?
Thank you very much
Re: Ev1527 Chinese devices
Posted: Tuesday 23 June 2020 8:35
by Dave21w
EV1527 based devices are already supported, just use the add switch command and press the button and it will save the device code, you will probably find though that these "switches" only send an "On" command with each press, this is because the device they normally connect to toggles it's state each time it receives the "On" signal. It's easy enough in blockly to create a toggle option to alter the state of another switch with each press of the wireless one, once completed you can then add a $ sign to the name of the wireless switch to hide it so you only see the device you want to control.
Posted: Wednesday 24 June 2020 9:05
by xavierlp
Thanks a lot Dave.
I will order it based on your feedback
Posted: Wednesday 24 June 2020 9:24
by Dave21w
I take it you already have either an RFXCom or RFLink for your 433Mhz devices ?
Posted: Thursday 25 June 2020 12:16
by xavierlp
Yes I do
A rfxcom RFXtrx433E.
thanks
Posted: Thursday 25 June 2020 16:23
by xavierlp
So I just received theses devices.
To integrate it, I used the switches panel, then the button learn Light/switch
I press the button of the device but Domoticz do not "find" it !
Any clues ?
- Capture d’écran (57).png (42.78 KiB) Viewed 8297 times
Posted: Friday 26 June 2020 8:02
by b_weijenberg
Use the latest Pro1 firmware in the RFXtrx433E.
Check with RFXmngr if the button is received.
Enable "add new devices" in Domoticz for 5 minutes.
Posted: Friday 26 June 2020 9:15
by xavierlp
Thanks a lot
It works now
Posted: Saturday 08 August 2020 11:24
by Jasper79
Dave21w wrote: Tuesday 23 June 2020 8:35
I found this thread and your comment because I also have these sensors and just started with Domoticz.
My RFLink found the front door and it does say ON all the time, If set manually to OFF it set ON when opening the door.
Could you give more details on how to make a script that records if the door has been opened?
Posted: Saturday 08 August 2020 11:36
by xavierlp
I bought a switch not a door contact. So it is different
Posted: Saturday 08 August 2020 12:21
by waaren
Jasper79 wrote: Saturday 08 August 2020 11:24
How do you see the device details on the device tab? Do you see Open / Closed or On / Off in the data column?
Posted: Saturday 08 August 2020 12:38
by Jasper79
On/Off, once its on it does not go off by itself.
I've been trying and it does seem to work like this.
- Screenshot_20200808-123628_Chrome.png (215.03 KiB) Viewed 8173 times
Posted: Saturday 08 August 2020 13:02
by waaren
Jasper79 wrote: Saturday 08 August 2020 12:38
That will work but does update your dummy device when there is any device activity on your system. Can you try changing the devicetype to doorcontact (on the switch tab) and use below dzVents script to toggle the contact n seconds after opening?
return
on =
devices =
'Door', -- set to name of your door contact
logging =
level = domoticz.LOG_DEBUG,
marker = 'Door',
execute = function(dz, item)
local toggleDelay = 10
local function toggleContact(dv, delay)
local delay = delay or 0
local iToggle = 1
if dv.state == 'Open' then iToggle = 0 end
local url = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=udevice&idx=' .. dv.idx .. '&nvalue=' .. iToggle
dz.openURL(url).afterSec(delay)
if item.state == 'Open' then
dz.notify('Door alert','Door is opened. Closing the contact in ' .. toggleDelay .. ' seconds')
dz.log('Door is opened. Closing the contact in ' .. toggleDelay .. ' seconds',dz.LOG_DEBUG)
toggleContact(item, toggleDelay)
Posted: Saturday 08 August 2020 15:00
by Jasper79
Setting it to door contact shows a closed/locked door icon and state closed.
Then opening the door shows a open door and state open.
Then nothing else happens after closing the door, It does not seem to reset.
On device I changed the name Door To Voordeur as in my devices list.
Everything else is untouched.
return
on =
devices =
'Voordeur', -- set to name of your door contact
logging =
marker = 'Door',
local iToggle = 1
2020-08-08 14:58:55.039 (RFLink) Light/Switch (Voordeur)
2020-08-08 14:58:55.281 Notification sent (browser) => Success
2020-08-08 14:58:55.248 Status: dzVents: Info: Handling events for: "Voordeur", value: "Open"
2020-08-08 14:58:55.249 Status: dzVents: Info: Voordeur: ------ Start internal script: Voordeur Test 2: Device: "Voordeur (RFLink)", Index: 138
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: Door is opened. Closing the contact in 10 seconds
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: OpenURL: url = http://127.0.0.1:8181/json.htm?type=command¶m=udevice&idx=138&nvalue=0
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: OpenURL: method = GET
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: OpenURL: post data = nil
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: OpenURL: headers = nil
2020-08-08 14:58:55.249 Status: dzVents: Debug: Voordeur: OpenURL: callback = nil
2020-08-08 14:58:55.250 Status: dzVents: Info: Voordeur: ------ Finished Voordeur Test 2
2020-08-08 14:58:55.279 Status: Notification: Door alert
2020-08-08 14:58:55.251 Error: dzVents: local netWork not open for dzVents openURL call !
2020-08-08 14:58:55.251 Error: dzVents: check dzVents wiki (look for 'Using dzVents with Domoticz'
Posted: Saturday 08 August 2020 15:07
by Jasper79
Fixed that,
make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password.
2020-08-08 15:05:08.019 Status: Incoming connection from: 127.0.0.1
2020-08-08 15:05:08.226 Status: dzVents: Info: Handling events for: "Voordeur", value: "Closed"
2020-08-08 15:05:08.226 Status: dzVents: Info: Voordeur: ------ Start internal script: Voordeur Test 2: Device: "Voordeur (RFLink)", Index: 138
2020-08-08 15:05:08.226 Status: dzVents: Info: Voordeur: ------ Finished Voordeur Test 2
Now it works.
I'll try for a couple a days before I move on to a siren
Maybe email notifications should go first.
Posted: Saturday 08 August 2020 18:20
by Jasper79
Next question,
Door number 2, new script or can it be added in the previous script?
return
on =
devices =
'Deursensor Voordeur', -- set to name of your door contact
'Deursensor Jenniffer',
--'Deursensor',
logging =
marker = 'Door',
local iToggle = 1
2020-08-08 18:18:26.790 Status: Notification: Door alert
2020-08-08 18:18:36.862 Status: Incoming connection from: 127.0.0.1
2020-08-08 18:18:37.068 Status: dzVents: Info: Handling events for: "Deursensor Jenniffer", value: "Closed"
2020-08-08 18:18:37.068 Status: dzVents: Info: Door: ------ Start internal script: Voordeur Test 2: Device: "Deursensor Jenniffer (RFLink)", Index: 150
2020-08-08 18:18:37.068 Status: dzVents: Info: Door: ------ Finished Voordeur Test 2
2020-08-08 18:18:50.824 Status: dzVents: Info: Handling events for: "Deursensor Jenniffer", value: "Open"
2020-08-08 18:18:50.825 Status: dzVents: Info: Door: ------ Start internal script: Voordeur Test 2: Device: "Deursensor Jenniffer (RFLink)", Index: 150
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: Door is opened. Closing the contact in 10 seconds
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: OpenURL: url = http://127.0.0.1:8181/json.htm?type=command¶m=udevice&idx=150&nvalue=0
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: OpenURL: method = GET
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: OpenURL: post data = nil
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: OpenURL: headers = nil
2020-08-08 18:18:50.825 Status: dzVents: Debug: Door: OpenURL: callback = nil
2020-08-08 18:18:50.825 Status: dzVents: Info: Door: ------ Finished Voordeur Test 2
Just to be sure, It does work .
Posted: Sunday 09 August 2020 8:11
by Dave21w
A quick question before I post my version as I don't want to make an idiot of myself.
Reading this script am I correct that after the door opens there is a delay and the script sets the door to closed again even if it's still open ?
Posted: Sunday 09 August 2020 8:35
by Jasper79
Indeed, why,. Well because the cheap sensor does not send a message when it's closed, it only sends a message when it opens so for the system it stays open forever.
I will need to buy new sensors some time.
Posted: Sunday 09 August 2020 10:06
by Dave21w
OK, thanks for the update, you should still have been able to reset the status in the switch itself instead of bothering with a script, simply set the off delay in the edit tab for the switch to say 20 seconds.
Dave
Posted: Sunday 09 August 2020 10:26
by Jasper79
Thanks, I didn't find a way to set it in the switch.
These are old chuango 433mhz door sensors that just send a signal to the main unit as far as I know.
Setting it to 20 seconds does not make much of a difference I think because like this morning the front door is open for a few hours to try and cool down the house.
I'm willing to try any changes, I'm pretty new to this so I'm relying on the community.
