Buienradar not working in 3.5.1 beta
Posted: Monday 22 June 2020 12:11
by Jimster
I upgraded to the latest beta and since then buienradar doesn't work anymore.
Any idea what I have to change to get it work again?
var frames = {}
frames.buienradar = {
frameurl:'https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.81&lng=4.67361&overname=2&zoom=8&naam=Dordrecht&size=2b&voor=1',
refreshiframe: 600000,
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
Re: Buienradar not working in 3.5.1 beta
Posted: Wednesday 24 June 2020 23:41
by clinkadink
I think your "refreshiframe" needs updating from milliseconds to seconds. Unless you mean to refresh it once per week
refreshiframe: 600000 // incorrect
refreshiframe: 60 // correct
https://dashticz.readthedocs.io/en/beta ... parameters
Posted: Wednesday 24 June 2020 23:48
by Lokonli
Jimster wrote:I upgraded to the latest beta and since then buienradar doesn't work anymore.
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
Can you try with forcerefresh:0?
Posted: Thursday 25 June 2020 16:11
by Lokonli
Jimster wrote: Monday 22 June 2020 12:11
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
and replace refreshiframe:600000 with refresh:600
(the parameter was renamed from refreshiframe to refresh, expressed in sec not msec.)
Posted: Thursday 25 June 2020 19:27
by Jimster
Lokonli wrote: Wednesday 24 June 2020 23:48
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
Yes, this did the trick! Thanks!
Posted: Thursday 25 June 2020 21:42
by Lokonli
Reason:
forcerefresh contained a bug, and was not applied to frames. I fixed this some time ago.
So after the bug fix forcerefresh:2 was applied to your buienradar frame, meaning the CORS proxy will be used.
However, buienradar.nl cannot be loaded via the CORS proxy ..., so that created your issue.
Anyway, good that it's solved
