Buienradar not working in 3.5.1 beta
Jimster
Post by Jimster »
I upgraded to the latest beta and since then buienradar doesn't work anymore.
Any idea what I have to change to get it work again?
var frames = {}
frames.buienradar = {
frameurl:'https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.81&lng=4.67361&overname=2&zoom=8&naam=Dordrecht&size=2b&voor=1',
refreshiframe: 600000,
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
clinkadink
Re: Buienradar not working in 3.5.1 beta
Post by clinkadink »
I think your "refreshiframe" needs updating from milliseconds to seconds. Unless you mean to refresh it once per week ;)
refreshiframe: 600000 // incorrect
refreshiframe: 60     // correct
https://dashticz.readthedocs.io/en/beta ... parameters
Lokonli
Post by Lokonli »
Jimster wrote:I upgraded to the latest beta and since then buienradar doesn't work anymore.
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
Can you try with forcerefresh:0?
Lokonli
Post by Lokonli »
Jimster wrote: Monday 22 June 2020 12:11 I upgraded to the latest beta and since then buienradar doesn't work anymore.
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
and replace refreshiframe:600000 with refresh:600
(the parameter was renamed from refreshiframe to refresh, expressed in sec not msec.)
Jimster
Post by Jimster »
Lokonli wrote: Wednesday 24 June 2020 23:48
var frames = {}
width: 12,
height: 330,
scrollbars: true,
forcerefresh: 2,
key: 'buienradar'
Yes, this did the trick! Thanks!
Lokonli
Post by Lokonli »
Reason:
forcerefresh contained a bug, and was not applied to frames. I fixed this some time ago.
So after the bug fix forcerefresh:2 was applied to your buienradar frame, meaning the CORS proxy will be used.
However, buienradar.nl cannot be loaded via the CORS proxy ..., so that created your issue.
Anyway, good that it's solved :)
