Script from voltage to percentage
Posted: Sunday 21 June 2020 15:01
by riekelt3
I have rainwater tank in my garden. I have a fibaro smart implant. I added already succesful to domoticz. I can now readout the voltage from the sensor. How can I change the data from voltage to percentage in a script? Please can anyone help me?
regards,
Riekelt
Re: Script from voltage to percentage
Posted: Sunday 21 June 2020 15:12
by waaren
riekelt3 wrote: Sunday 21 June 2020 15:01
What is the type and subtype (devices tab) of the current sensor?
What is the min and max voltage?
Should min voltage be 0% and max voltage be 100%?
What should be the frequency to update the virtual percentage sensor? (every change in voltage or every minute or every hour or something else)
Posted: Sunday 21 June 2020 21:07
by riekelt3
Thanks for the quick reply. I will figure it out and discribe it out.
Riekelt
Posted: Monday 22 June 2020 13:36
by riekelt3
The type of the sensor is: general and the subtype: voltage
The min voltage is: 1,45V and the Max: 2,06V
Yes the min voltage should be 0% and the max voltage should be 100%
The frequence should be every change in voltage
Riekelt
Posted: Monday 22 June 2020 23:08
by waaren
riekelt3 wrote: Monday 22 June 2020 13:36
Could be something like
return
on =
devices =
'waterLevelVoltage' -- change to name of voltage device
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script executes without issues
marker = 'watertank level',
execute = function(dz, item)
local measuredVoltage = item.voltage
local tankLevelIndicator = dz.devices('waterLevel') -- change to name of percentage device
local minVoltage = 1.45
local maxVoltage = 2,06
local function guardPercentage( percentage )
if percentage > 0.05 and percentage <= 100 then return percentage end
dz.log('Unexpected voltage (' .. percentage .. ')', dz.LOG_ERROR)
if percentage > 100 then return 100 else return 0 end
local levelPercentage = dz.utils.round( guardPercentage ( ( measuredVoltage - minVoltage ) * ( 100 / ( maxVoltage - minVoltage ) ) ) ,1 )
dz.log('Percentage = ' .. levelPercentage, dz.LOG_DEBUG)
tankLevelIndicator.updatePercentage(levelPercentage)
Posted: Friday 26 June 2020 20:06
by riekelt3
The script is working. I am very happy with this. Only when I see the voltage and the percentage it is for 2 seconds. And than the voltage and percentage go to 0. Untill the next voltage is coming from the sensor.
Posted: Saturday 27 June 2020 7:33
by waaren
riekelt3 wrote: Friday 26 June 2020 20:06
if domoticz receive a volt update it will update the volt sensor. Not much you can do about that. The percentage sensor is controlled by dzVents.
You could change the guardPercentage function to
if percentage >= 0.1 and percentage <= 100 then return percentage end
dz.log('Unexpected voltage (' .. percentage .. ')', dz.LOG_DEBUG)
return 100
return tankLevelIndicator.percentage
This will prevent the 0 update to mess with the level
Re: Script from voltage to percentage [Solved]
Posted: Sunday 28 June 2020 20:20
by riekelt3
It's working now for 100%. Thank you for the support. I am very happy with this.
Posted: Thursday 30 July 2020 15:58
by heistje
I also used this script for a my garden watertank, not with a fibaro smart implant but with a Water Level Sensor I bought at Aliexpress:
https://www.aliexpress.com/item/4000098 ... c4dO2kw75)
and
a ETH8020 (analog input 0-5VDC)
Would like to thank you guys! Thanks to this script it works like a charm!
Posted: Friday 18 February 2022 14:48
by Drdre
I also need a script but then from voltage (0-5) to windspeed km/h (0-100).
Sombody can help me with this script?
Posted: Friday 18 February 2022 14:58
by waltervl
Drdre wrote: Friday 18 February 2022 14:48
You can use the script above but make some modifications.
But what is your formula to go from voltage to windspeed?
Posted: Friday 18 February 2022 15:08
by waltervl
Assuming 0 volt = 0 kmh and 5 volt = 100 kmh so a factor 20:
formula kmh = V*20
NOT TESTED!!! Could contain Error!!!
return
on =
devices =
'windspeedvoltage' -- change to name of voltage device
logging =
marker = 'windspeed',
local WindspeedDevice = dz.devices('windspeed') -- change to name of Custom Sensor for windspeed.
local windspeed = dz.utils.round( measuredVoltage * 20 ,1 )
dz.log('Wind Speed = ' .. windspeed, dz.LOG_DEBUG)
WindspeedDevice.updateCustomSensor(windspeed)
Posted: Sunday 20 February 2022 15:34
by Drdre
It's working thanks!!!!!
