Script from voltage to percentage  [Solved]
riekelt3
Post by riekelt3 »
I have rainwater tank in my garden. I have a fibaro smart implant. I added already succesful to domoticz. I can now readout the voltage from the sensor. How can I change the data from voltage to percentage in a script? Please can anyone help me?
regards,
Riekelt
Re: Script from voltage to percentage
riekelt3 wrote: Sunday 21 June 2020 15:01 I have rainwater tank in my garden. I have a fibaro smart implant. I added already succesful to domoticz. I can now readout the voltage from the sensor. How can I change the data from voltage to percentage in a script? Please can anyone help me?
What is the type and subtype (devices tab) of the current sensor?
What is the min and max voltage?
Should min voltage be 0% and max voltage be 100%?
What should be the frequency to update the virtual percentage sensor? (every change in voltage or every minute or every hour or something else)
riekelt3
Post by riekelt3 »
Thanks for the quick reply. I will figure it out and discribe it out.
Riekelt
riekelt3
Post by riekelt3 »
The type of the sensor is: general and the subtype: voltage
The min voltage is: 1,45V and the Max: 2,06V
Yes the min voltage should be 0% and the max voltage should be 100%
The frequence should be every change in voltage
Riekelt
riekelt3 wrote: Monday 22 June 2020 13:36 The frequence should be every change in voltage
Could be something like
return
    on =
        devices =
            'waterLevelVoltage'      -- change to name of voltage device
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script executes without issues
        marker = 'watertank level',
    execute = function(dz, item)
        local measuredVoltage = item.voltage
        local tankLevelIndicator = dz.devices('waterLevel') -- change to name of percentage device
        local minVoltage = 1.45
        local maxVoltage = 2,06
        local function guardPercentage( percentage )
           if percentage > 0.05 and percentage <= 100 then return percentage end
           dz.log('Unexpected voltage (' .. percentage .. ')', dz.LOG_ERROR)
           if percentage > 100 then return 100 else return 0 end
        local levelPercentage = dz.utils.round( guardPercentage ( ( measuredVoltage - minVoltage ) * ( 100 / ( maxVoltage - minVoltage ) ) ) ,1 )
        dz.log('Percentage = ' .. levelPercentage, dz.LOG_DEBUG)
        tankLevelIndicator.updatePercentage(levelPercentage)
riekelt3
Post by riekelt3 »
The script is working. I am very happy with this. Only when I see the voltage and the percentage it is for 2 seconds. And than the voltage and percentage go to 0. Untill the next voltage is coming from the sensor.
riekelt3 wrote: Friday 26 June 2020 20:06 The script is working. I am very happy with this. Only when I see the voltage and the percentage it is for 2 seconds. And than the voltage and percentage go to 0. Untill the next voltage is coming from the sensor.
if domoticz receive a volt update it will update the volt sensor. Not much you can do about that. The percentage sensor is controlled by dzVents.
You could change the guardPercentage function to
            if percentage >= 0.1 and percentage <= 100 then return percentage end
            dz.log('Unexpected voltage (' .. percentage .. ')', dz.LOG_DEBUG)
                return 100
                return tankLevelIndicator.percentage
This will prevent the 0 update to mess with the level
riekelt3
Re: Script from voltage to percentage  [Solved]
Post by riekelt3 »
It's working now for 100%. Thank you for the support. I am very happy with this.
heistje
Domoticz version: 2023.2
Post by heistje »
I also used this script for a my garden watertank, not with a fibaro smart implant but with a Water Level Sensor I bought at Aliexpress: https://www.aliexpress.com/item/4000098 ... c4dO2kw75)
and
a ETH8020 (analog input 0-5VDC)
Would like to thank you guys! Thanks to this script it works like a charm!
Bullseye on RPI 4
Aeotec Z-Wave Plus Z-Stick Gen5
Zwave-JS-UI
RFXtrx433E
Eth8020
P1 USB
Shellys
ESP8266
Drdre
Post by Drdre »
I also need a script but then from voltage (0-5) to windspeed km/h (0-100).
Sombody can help me with this script?
Domoticz version: 2024.7
Drdre wrote: Friday 18 February 2022 14:48 I also need a script but then from voltage (0-5) to windspeed km/h (0-100).
You can use the script above but make some modifications.
But what is your formula to go from voltage to windspeed?
Assuming 0 volt = 0 kmh and 5 volt = 100 kmh so a factor 20:
formula kmh = V*20
NOT TESTED!!! Could contain Error!!!
return
    on =
        devices =
            'windspeedvoltage'      -- change to name of voltage device
    logging =
        marker = 'windspeed',
        local WindspeedDevice = dz.devices('windspeed') -- change to name of Custom Sensor for windspeed.
        local windspeed = dz.utils.round( measuredVoltage  * 20 ,1 )
        dz.log('Wind Speed = ' .. windspeed, dz.LOG_DEBUG)
        WindspeedDevice.updateCustomSensor(windspeed)
Drdre
Post by Drdre »
It's working thanks!!!!!
