Can't get this sunrise/sunset script triggered [SOLVED]
MadMedic
Post by MadMedic »
Hi guys,
A while ago I found this sunset/sunrise dz vents script in this forum,
but doesn't matter what I try, I can't seem to get this script triggered.
No mentioning in logs that is has been triggered too.
Perhaps someone can help me, please ? Can it be a timer issue ?
(and yes, I activated DZ vents on the settingspage.
And the names of the textdevices are the exact same as in this script)
    on          =   {
                        timer           =   { "at 00.03", "at 06:03" },
                    }, -- twice a day to be sure and 3 min past the hour because at the hour already quite busy
    execute = function( dz )
        local function minutes2time(minutes)   -- integer in; string out
            local hour      = string.format("%02d",math.floor(minutes / 60))
            local minutes   = string.format("%02d",minutes - (hour * 60))
            return (hour .. ":" .. minutes) --  string out
        dz.devices("Sunset").updateText(minutes2time(dz.time.sunsetInMinutes))
        dz.devices("Sunrise").updateText(minutes2time(dz.time.sunriseInMinutes))
"Life is too short for bad coffee"
Re: Can't get this sunrise/sunset script triggered
MadMedic wrote: Saturday 20 June 2020 14:07 A while ago I found this sunset/sunrise dz vents script in this forum,
In this copy of the script you used "at 00.03" as a trigger time. The notation should be "at 00:03"
If you modify and save the script do you see that it is saved in the log ?
I added some logging to see what happens when the script executes.
return
    on =
        timer =
            'at 00:03',
            'at 06:03'
    logging =
        logging = domoticz.LOG_DEBUG,
        marker = 'times',
            local hour = string.format('%02d', math.floor(minutes / 60))
            local minutes = string.format('%02d', minutes - (hour * 60))
            return (hour .. ':' .. minutes) --  string out
        dz.devices('Sunset').updateText(minutes2time(dz.time.sunsetInMinutes))
        dz.devices('Sunrise').updateText(minutes2time(dz.time.sunriseInMinutes))
MadMedic
Post by MadMedic »
Hi Waaren (to the rescue again)
Already found this wrong time format too using the DZvents timer documentation on Domoticz.com (RTFM, Medic)
So you're totally right, its working now.. Thanks anyway for your time. ^5
But for the following users of this script perhaps it is good to know.
