One script to match multiple devices
Posted: Monday 15 June 2020 12:45
by shketiev
I have about 200 panic buttons connected to my domoticz with mysensors gateways. These are push buttons , but I added every button as a door contact , because of automatic release. I want to send notification when button is pressed and I can make it from notification section of every single one , but I want to make a script that matches all of them and send notifications when button is pressed , 1 script for all. I set the names for example: PANIC - 1 , PANIC - 2 , PANIC - 3 and so on ... And the script have to be something like:
if (devicechanged['PANIC ???something*'] == 'Closed') then
commandArray['SendNotification']='.. devicename button pressed'
Please anyone help with that.....
Re: One script to match multiple devices
Posted: Monday 15 June 2020 13:19
by jvdz
Something like this?:
for dev, status in pairs(devicechanged) do
-- Check Panicbutton pressed
if (dev:sub(1, 6) == 'PANIC '] and status == 'Closed') then
commandArray['SendNotification']= dev ..' button pressed'
Jos
Posted: Monday 15 June 2020 13:49
by shketiev
jvdz wrote: Monday 15 June 2020 13:19
Jos
Thank you very much ! Yes , exactly like this , but:
It returns error for some reason , Domoticz 2020.2
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:4: ')' expected near ']'
Posted: Tuesday 16 June 2020 7:21
by jake
shketiev wrote:jvdz wrote: Monday 15 June 2020 13:19
Jos
Yes, because of the ] behind the word panic? Please remove.
Posted: Tuesday 16 June 2020 11:08
by shketiev
I noticed that , and I actually see that I have posted previous error. After I remove ] after PANIC ' the error is on line 2.
Error: EventSystem: in PANIC Button: [string "commandArray = {} ..."]:2: bad argument #1 to 'pairs' (table expected, got nil)
I don't why this error appears (every 60 seconds), but the script actually works and notifications is received correctly.
Posted: Tuesday 16 June 2020 11:57
by waaren
shketiev wrote: Tuesday 16 June 2020 11:08
You should save the Lua script as triggered on Device. You now probably saved it to be triggered on 'All'
top right corner of the edit window..
- trigger.png (5.12 KiB) Viewed 1529 times
Posted: Tuesday 16 June 2020 12:33
by shketiev
waaren wrote: Tuesday 16 June 2020 11:57
YEAH , that works , no more errors. Thank you very much !
Posted: Saturday 25 July 2020 15:36
by shketiev
Just wondering , how can I add some limiting option for example:
If button is pressed , send notification , but once a minute , or every X time.
Now when someone press the button multiple times , it floods the system
Thanks !
Posted: Saturday 25 July 2020 17:01
by waaren
shketiev wrote: Saturday 25 July 2020 15:36
Could look like
local function string2Epoch(dateString, pattern)
local pattern = pattern or '(%d+)-(%d+)-(%d+) (%d+):(%d+):(%d+)'
local year, month, day, hour, minute, seconds = dateString:match(pattern)
return os.time({year = year, month = month, day = day , hour = hour, min = minute, sec = seconds })
if dev:sub(1, 5) == 'PANIC' and status == 'Closed' then
local secondsAgo = os.time() - string2Epoch(otherdevices_lastupdate[dev])
if secondsAgo > 60 then
commandArray['SendNotification']= dev ..' button was pressed before ' .. secondsAgo .. ' seconds Ago'
print('No notification send. Last update of ' .. dev .. ' was ' .. secondsAgo .. ' seconds Ago')
-- commandArray[#commandArray+1] = {[dev] = 'Open NOTRIGGER'} -- Don't know if this is needed and if so it works. Just try after confirming the other part does work
