set selector switch with JSON in version 2020.2?
Posted: Wednesday 10 June 2020 7:26
by renerene
This used to work in HABridge
http://192.168.0.xxx:xxxx//json.htm?type=command¶m=switchlight&idx=1425&switchcmd=Set%20Level&level=120
But after update to latest beta Version: 2020.2 (build 12138) HABridge reports error in log:
2020-06-10 07:24:00,307 [qtp16705701-16] WARN com.bwssystems.HABridge.plugins.domoticz.DomoticzHome - Cannot interrpret result from call for Domoticz domoticz as response is not parsable.
2020-06-10 07:24:00,309 [qtp16705701-16] WARN com.bwssystems.HABridge.hue.HueMulator - On/Off Request failed with: [{"error":{"type":"6","address":"/lights/110","description":"Error on calling url to change device state","method_name":"/lights/110/state"}}]
Re: set selector switch with JSON in version 2020.2?
Posted: Wednesday 10 June 2020 8:21
by waaren
renerene wrote: Wednesday 10 June 2020 7:26
If you replace //json.htm with /json.htm it should work .(Just tested with latest beta)
If stil not OK then try to enter the URL in your browser. Maybe it will show what's going on.
Posted: Wednesday 10 June 2020 14:56
by renerene
Thank you Waaren. Just did a quick test in address bar of browser and this time domoticz returns with asking login credentials (previous error 404). Will make it work this evening, when I have more time. Strange why the two "//" were there....
Seems like option in Domoticz settings to exclude local network devices from login is not working in this latest beta version. In Dashticz I also had to fill in login name and password, which was not needed before.
Posted: Wednesday 10 June 2020 18:08
by waaren
renerene wrote: Wednesday 10 June 2020 14:56
What do have in the local network (no username/password) field?.
For some forum members it was needed to add ;::1
- settings.png (32.57 KiB) Viewed 3645 times
Posted: Wednesday 10 June 2020 18:31
by HansieNL
Sorry to break in, but what does the ::1 exactly do?
Posted: Wednesday 10 June 2020 19:04
by waaren
HansieNL wrote: Wednesday 10 June 2020 18:31
Short answer: In this context it is the IPv6 equivalent of localhost (127.0.0.1 in IPv4)
wiki (
Long explanation )
