set selector switch with JSON in version 2020.2?
renerene
Post by renerene »
This used to work in HABridge
http://192.168.0.xxx:xxxx//json.htm?type=command&param=switchlight&idx=1425&switchcmd=Set%20Level&level=120
But after update to latest beta Version: 2020.2 (build 12138) HABridge reports error in log:
2020-06-10 07:24:00,307 [qtp16705701-16] WARN  com.bwssystems.HABridge.plugins.domoticz.DomoticzHome - Cannot interrpret result from call for Domoticz domoticz as response is not parsable.
2020-06-10 07:24:00,309 [qtp16705701-16] WARN  com.bwssystems.HABridge.hue.HueMulator - On/Off Request failed with: [{"error":{"type":"6","address":"/lights/110","description":"Error on calling url to change device state","method_name":"/lights/110/state"}}]
Re: set selector switch with JSON in version 2020.2?
renerene wrote: Wednesday 10 June 2020 7:26 This used to work in HABridge
If you replace //json.htm with /json.htm it should work .(Just tested with latest beta)
If stil not OK then try to enter the URL in your browser. Maybe it will show what's going on.
renerene
Post by renerene »
Thank you Waaren. Just did a quick test in address bar of browser and this time domoticz returns with asking login credentials (previous error 404). Will make it work this evening, when I have more time. Strange why the two "//" were there....
Seems like option in Domoticz settings to exclude local network devices from login is not working in this latest beta version. In Dashticz I also had to fill in login name and password, which was not needed before.
renerene wrote: Wednesday 10 June 2020 14:56 Seems like option in Domoticz settings to exclude local network devices from login is not working in this latest beta version. In Dashticz I also had to fill in login name and password, which was not needed before.
What do have in the local network (no username/password) field?.
For some forum members it was needed to add ;::1
HansieNL
Post by HansieNL »
Sorry to break in, but what does the ::1 exactly do?
Blah blah blah
HansieNL wrote: Wednesday 10 June 2020 18:31 Sorry to break in, but what does the ::1 exactly do?
Short answer: In this context it is the IPv6 equivalent of localhost (127.0.0.1 in IPv4)
wiki ( Long explanation )
