icons not working
bobpeters
icons not working
Post by bobpeters »
Don't know if its a bug or not. But I'm struggeling with some icons from FontAwesome. A lot of icons are not working in my dasboard and it seems that Dashticz pics a default one then. For example, my solar power:
//GoodWe opbrengst PV panelen
blocks[443] = {
width: 6,
title: 'ZoPa Opbrengst',
icon: 'fas fa-solar-panel'
Looks like this:
Aantekening 2020-06-09 163844.png (26.92 KiB) Viewed 2829 times
I only choose free icons from the website.
I updated today to the latest version of Dashticz
Debian Buster on RPi 3B, Domoticz, RFXcom433e, KaKu, P1 cable, Proximity sensor for watermeter, Dashticz
Lokonli
Re: icons not working
Post by Lokonli »
bobpeters wrote: Tuesday 09 June 2020 16:44 Don't know if its a bug or not. But I'm struggeling with some icons from FontAwesome. A lot of icons are not working in my dasboard and it seems that Dashticz pics a default one then. For example, my solar power:
blocks[443] = {
width: 6,
Looks like this:
It should work.
Can you check in Chrome? First completely clean the cache.
Do you have any code in custom.js?
Or some special things in CONFIG.js?
bobpeters
Post by bobpeters »
In Chrome it is also not working, tried on Windows and Mac.
CONFIG.js see below (some parts deleted "XXX")
CUSTOM.js, nothing changed
CUSTOM.css, only the border width changed for better view on small tablet screen
//Somfy Zonnescherm
blocks[484] = {
 title: 'Zon',
 width: 4
//Somfy Rolluik slk b/m
blocks[224] = {
 title: 'Slk',
 width: 4
//Somfy Rolluik slk Cas
blocks[547] = {
title: 'Cas',
width: 4
//Somfy rolluik kmr Tom
blocks[225] = {
 title: 'Tom',
 width: 4
blocks[443] = {
  width: 6,
//P1 slimme meter Stroomverbruik
blocks[77] = {
  width: 6,
title: 'Stroomverbruik',
icon: 'fas fa-bolt'
//Watermeter
blocks[572] = {
  width: 4,
title: 'Watermeter',
icon: 'fas fa-water'
Lokonli
Post by Lokonli »
I see you defined blocks[443] and added '443_1' to a column. I think that in this case '443_1' will not use the block[443] definition
So try with:
blocks['443_1'] = {
  width: 6,
bobpeters
Post by bobpeters »
Lokonli wrote: Tuesday 09 June 2020 20:56 I see you defined blocks[443] and added '443_1' to a column. I think that in this case '443_1' will not use the block[443] definition
So try with:
blocks['443_1'] = {
  width: 6,
This was the problem, thanks a lot!
