Hello everyone, I'm new to Domoticz, I just bought SONOFF switches which I will flash to install Tasmota. I was wondering what I could set up as a Domoticz compatible sensor but preferably wifi. I am looking to have the temperature, the movement and if possible bulb connected. Do you have a list of compatible hardware?
Thanks in advance to everyone for your help. Good evening
Wifi device ?
- Domoticz version: 2020.1
Re: Wifi device ?
I use a D1 mini with Tasmota along with MQTT and Node Red to get the data into Domoticz
I've used DH22 for Temperature and HC-SR501 for motion but you have to keep this device some distance away from the D1 because of interferance from the D1 mini WIFI
Re: Wifi device ?
Thanks for sharing
- Domoticz version: V2024.4
Re: Wifi device ?
you can also take a look here :
https://shelly.cloud/
- McMelloW
- Domoticz version: V2024.1
Re: Wifi device ?
Use a MQTT broker. Dummy switch in Domoticz. Flash Sonoff with Tasmota. Configure Sonoff to MQTT and for Domoticz with idx of the Dummy switchalxinfo wrote: ↑Monday 08 June 2020 20:49 Hello everyone, I'm new to Domoticz, I just bought SONOFF switches which I will flash to install Tasmota. I was wondering what I could set up as a Domoticz compatible sensor but preferably wifi. I am looking to have the temperature, the movement and if possible bulb connected. Do you have a list of compatible hardware?
Greetings McMelloW
