Timer trigger over midnight (and some other script problems)
Posted: Monday 08 June 2020 13:08
by AllesVanZelf
From Blockly I know that if you want to have a time span over midnight, you have to do this as:
> sunset OR < sunrise.
How would I do this in DzVents?
Can I do this as:
Between sunset and sunrise?
Re: Timer trigger over midnight
Posted: Monday 08 June 2020 13:55
by waaren
AllesVanZelf wrote: Monday 08 June 2020 13:08
Can I do this as:
From the
wiki chapter on timer trigger rules
'between aa and bb' -- aa/bb can be sunrise/sunset
and
'at nighttime', -- between sunset and sunrise
Posted: Monday 08 June 2020 13:59
by AllesVanZelf
Yes I've read that, but it was not clear to me that this would also work over midnight. (i missed that comments
at nighttime is a good one!
Thanks again!
Posted: Monday 08 June 2020 15:44
by AllesVanZelf
These are some of my first steps in DzVents. A few scripts are working well and a little better then blockly's.
But this one gives me (almost) headache.
return
on =
timer =
'at nighttime',
devices =
'MS-Buiten',
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz)
local voordeurlamp = dz.devices('Lamp Voordeur Schakelaar')
local keukenlamp = dz.devices('Lamp-Keuken-Sier-433')
local voorhuis = dz.devices('Lamp Voorhuis Powerplug')
local motion = dz.devices('MS-Buiten').state
if dz.time.matchesRule('at daytime') and voordeurlamp == 'Off' and motion == 'On' then
voordeurlamp.switchOn().silent().afterSec(20)
keukenlamp.switchOn().silent().afterSec(40)
voorhuis.switchOn().silent().afterSec(60)
voorhuis.switchOff().afterSec(250)
keukenlamp.switchOff().afterSec(300)
voordeurlamp.switchOff().afterSec(400)
dz.utils.osExecute('/home/pi/bin/sendsnapshot-nacht.sh')
This script should turn on some light in a special order and then turn them off after some time. In the same time the sh script should send me a snapshot. This snapshot works from commandline in raspberry os.
But nothing happens. No light, no message. (I tested with daytime.)
Log does not help me a lot:
2020-06-08 15:40:34.018 Status: dzVents: Info: ------ Start internal script: Beweging buiten Licht DzVents: Device: "MS-Buiten (Virtuele schakelaarrs)", Index: 7
2020-06-08 15:40:34.019 Status: dzVents: Debug: Processing device-adapter for Lamp Voordeur Schakelaar: Switch device adapter
2020-06-08 15:40:34.021 Status: dzVents: Debug: Processing device-adapter for Lamp-Keuken-Sier-433: Switch device adapter
2020-06-08 15:40:34.023 Status: dzVents: Debug: Processing device-adapter for Lamp Voorhuis Powerplug: Switch device adapter
2020-06-08 15:40:34.023 Status: dzVents: Info: ------ Finished Beweging Licht DzVents
There is something wrong in the code. but what?
Posted: Monday 08 June 2020 17:36
by waaren
AllesVanZelf wrote: Monday 08 June 2020 15:44
First some remarks / questions.
this script will be triggered every minute at nighttime and every time MS-Buiten is updated. Is that your intention or do you only want it to be triggered when MS-Buiten is updated during nighttime?
You check if voordeurlamp is 'Off' but voordeurlamp is a device object. You probably want to check it's state like you do for motion.
it then would be something like below
return
on =
devices =
['MS-Buiten'] =
'at nighttime'
logging =
if voordeurlamp.state == 'Off' and motion == 'On' then
os.execute('/home/pi/bin/sendsnapshot-nacht.sh')
Posted: Monday 08 June 2020 17:39
by waaren
If you need more logging, add some lines at relevant places in your script like
dz.log('State of voordeurlamp is ' .. voordeurlamp.state, dz.LOG_DEBUG )
Posted: Monday 08 June 2020 18:17
by AllesVanZelf
waaren wrote: Monday 08 June 2020 17:36
Yes the latter. When MS Buiten is triggered at nighttime.
What do the brackets [] arround MS-Buiten mean in this case?
waaren wrote: Monday 08 June 2020 17:36You check if voordeurlamp is 'Off' but voordeurlamp is a device object. You probably want to check it's state like you do for motion.
That is true. That means that I forgot the .state part. isn't it?
I did not find the os.execute part in wiki. I did see something about osExecute(cmd) and read about it in some other posts. But I find it hard to use in code.
If the code works well do I change the log line:
to dz.LOG_INFO or just dz.LOG? Or just rmeove the line?
and what about this part:
logging =
Posted: Monday 08 June 2020 18:40
by waaren
AllesVanZelf wrote: Monday 08 June 2020 18:17
[Yes the latter. When MS Buiten is triggered at nighttime.
it means that MS-Buiten is to be considered as a key in a Lua table.
Yes
os.execute is standard Lua. dzVents is 100% Lua
In the dzVents wiki you will see the specific dzVents API (functions, attributes, structures) Guides on all standard Lua commands and structures are freely and in large amounts available on the web. As a start you can look
here
Just leave it as it is
logging =
change that to
logging =
level = domoticz.LOG_ERROR,
Re: Timer trigger over midnight (and some other script problems)
Posted: Monday 08 June 2020 18:54
by AllesVanZelf
Ok Thanks for these explanations!!
