Timer trigger over midnight (and some other script problems)
AllesVanZelf
- Domoticz version: 12467
From Blockly I know that if you want to have a time span over midnight, you have to do this as:
> sunset OR < sunrise.
How would I do this in DzVents?
Can I do this as:
Between sunset and sunrise?
Can I do this as:
Last edited by AllesVanZelf on Monday 08 June 2020 16:02, edited 2 times in total.
- waaren
Re: Timer trigger over midnight
From the wiki chapter on timer trigger rulesAllesVanZelf wrote: Monday 08 June 2020 13:08 > sunset OR < sunrise.
Can I do this as:
and'between aa and bb' -- aa/bb can be sunrise/sunset
'at nighttime', -- between sunset and sunrise
AllesVanZelf
Yes I've read that, but it was not clear to me that this would also work over midnight. (i missed that comments
at nighttime is a good one!
Thanks again!
Thanks again!
AllesVanZelf
These are some of my first steps in DzVents. A few scripts are working well and a little better then blockly's.
But this one gives me (almost) headache.
This script should turn on some light in a special order and then turn them off after some time. In the same time the sh script should send me a snapshot. This snapshot works from commandline in raspberry os.
But nothing happens. No light, no message. (I tested with daytime.)
Log does not help me a lot:
There is something wrong in the code. but what?
return
on =
timer =
'at nighttime',
devices =
'MS-Buiten',
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz)
local voordeurlamp = dz.devices('Lamp Voordeur Schakelaar')
local keukenlamp = dz.devices('Lamp-Keuken-Sier-433')
local voorhuis = dz.devices('Lamp Voorhuis Powerplug')
local motion = dz.devices('MS-Buiten').state
if dz.time.matchesRule('at daytime') and voordeurlamp == 'Off' and motion == 'On' then
voordeurlamp.switchOn().silent().afterSec(20)
keukenlamp.switchOn().silent().afterSec(40)
voorhuis.switchOn().silent().afterSec(60)
voorhuis.switchOff().afterSec(250)
keukenlamp.switchOff().afterSec(300)
voordeurlamp.switchOff().afterSec(400)
dz.utils.osExecute('/home/pi/bin/sendsnapshot-nacht.sh')
}But nothing happens. No light, no message. (I tested with daytime.)
2020-06-08 15:40:34.018 Status: dzVents: Info: ------ Start internal script: Beweging buiten Licht DzVents: Device: "MS-Buiten (Virtuele schakelaarrs)", Index: 7
2020-06-08 15:40:34.019 Status: dzVents: Debug: Processing device-adapter for Lamp Voordeur Schakelaar: Switch device adapter
2020-06-08 15:40:34.021 Status: dzVents: Debug: Processing device-adapter for Lamp-Keuken-Sier-433: Switch device adapter
2020-06-08 15:40:34.023 Status: dzVents: Debug: Processing device-adapter for Lamp Voorhuis Powerplug: Switch device adapter
2020-06-08 15:40:34.023 Status: dzVents: Info: ------ Finished Beweging Licht DzVents Domoticz 2020.1 (12230) on Raspberry Pi 3B with Raspian Buster. Besides Domoticz, Rpi is running Pi-Hole.
- waaren
First some remarks / questions.AllesVanZelf wrote: Monday 08 June 2020 15:44 But this one gives me (almost) headache.
this script will be triggered every minute at nighttime and every time MS-Buiten is updated. Is that your intention or do you only want it to be triggered when MS-Buiten is updated during nighttime?
You check if voordeurlamp is 'Off' but voordeurlamp is a device object. You probably want to check it's state like you do for motion.
it then would be something like below
return
on =
devices =
['MS-Buiten'] =
'at nighttime'
logging =
if voordeurlamp.state == 'Off' and motion == 'On' then
os.execute('/home/pi/bin/sendsnapshot-nacht.sh')
}Debian buster, bullseye on RPI-4, Intel NUC.
- waaren
If you need more logging, add some lines at relevant places in your script like
dz.log('State of voordeurlamp is ' .. voordeurlamp.state, dz.LOG_DEBUG )Debian buster, bullseye on RPI-4, Intel NUC.
AllesVanZelf
Yes the latter. When MS Buiten is triggered at nighttime.waaren wrote: Monday 08 June 2020 17:36 this script will be triggered every minute at nighttime and every time MS-Buiten is updated. Is that your intention or do you only want it to be triggered when MS-Buiten is updated during nighttime?
What do the brackets [] arround MS-Buiten mean in this case?
That is true. That means that I forgot the .state part. isn't it?waaren wrote: Monday 08 June 2020 17:36You check if voordeurlamp is 'Off' but voordeurlamp is a device object. You probably want to check it's state like you do for motion.
I did not find the os.execute part in wiki. I did see something about osExecute(cmd) and read about it in some other posts. But I find it hard to use in code.
If the code works well do I change the log line:
dz.log('State of voordeurlamp is ' .. voordeurlamp.state, dz.LOG_DEBUG )and what about this part:
logging =
},Domoticz 2020.1 (12230) on Raspberry Pi 3B with Raspian Buster. Besides Domoticz, Rpi is running Pi-Hole.
- waaren
it means that MS-Buiten is to be considered as a key in a Lua table.AllesVanZelf wrote: Monday 08 June 2020 18:17 [Yes the latter. When MS Buiten is triggered at nighttime.
YesThat is true. That means that I forgot the .state part. isn't it?
os.execute is standard Lua. dzVents is 100% LuaI did not find the os.execute part in wiki. I did see something about osExecute(cmd) and read about it in some other posts. But I find it hard to use in code.
In the dzVents wiki you will see the specific dzVents API (functions, attributes, structures) Guides on all standard Lua commands and structures are freely and in large amounts available on the web. As a start you can look here
Just leave it as it isIf the code works well do I change the log line:to dz.LOG_INFO or just dz.LOG? Or just rmeove the line?Code: Select all
change that toand what about this part:Code: Select all
logging = { level = domoticz.LOG_DEBUG, },
logging =
level = domoticz.LOG_ERROR,
},Debian buster, bullseye on RPI-4, Intel NUC.
AllesVanZelf
Re: Timer trigger over midnight (and some other script problems)
Ok Thanks for these explanations!!
