BuienRadar invalid data
This morning around 10.30 CET my BuienRadar hardware started reporting the following error every 10 minutes:
Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
After disable/enable it now tells me: 2020-06-08 12:05:32.273 Error: BuienRadar: No (nearby) station found!
I am suspecting that the BuienRadar API has changed. Can somone give a clue how to further investigate (and possibly resolve) this?
I am running stable version 2020.2.
- waaren
Re: BuienRadar invalid data
The API has not changed but Buienradar does return 0,0 for lat,lon. We have seen this before and after notifying buienradar they solved it within a day.forkboy wrote: ↑Monday 08 June 2020 12:20 This morning around 10.30 CET my BuienRadar hardware started reporting the following error every 10 minutes:
I am suspecting that the BuienRadar API has changed. Can someone give a clue how to further investigate (and possibly resolve) this?
You can chek this by entering https://data.buienradar.nl/2.0/feed/json in your browser address-bar
- McMelloW
- Domoticz version: V2024.1
In my Hardware setup for BuiennRadar I use the SationID. Never the less, I got the following errors
I did send in a message at the BuienRader contact page about it.
2020-06-08 13:32:50.739 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
2020-06-08 13:42:51.752 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
2020-06-08 13:52:52.639 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
Greetings McMelloW
- waaren
Is indeed confusing.McMelloW wrote: ↑Monday 08 June 2020 14:02 In my Hardware setup for BuiennRadar I use the SationID. Never the less, I got the following errorsI did send in a message at the BuienRader contact page about it.Code: Select all
2020-06-08 13:32:50.739 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned! 2020-06-08 13:42:51.752 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned! 2020-06-08 13:52:52.639 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
If you enter a stationID in the setup the buienradar data wil be collected if the station is alive. For rainforecast data another URL is called and that URL need a lat/lon. If you set a a stationID in the setup, the lat/lon are to be received from the reply of your chosen station but in this case they are both 0, 0 in that reply.
So there seems to be room for improvement: with a stationid in the hardware we could at least get the basic weather information, without the rain forecast.
it's a serverside issue.
- in this url https://data.buienradar.nl/2.0/feed/json long/lat is 0,0 for every station. So domoticz cannot determine the locations of the id's and can therefor not find the nearest station
- in this url https://observations.buienradar.nl/1.0/ ... stationid> the stationid tag is changed. domoticz is expecting stationid, but is getting stationId (notice the capital I).
so providing the stationid in the config will not fix it.
- FireWizard
Same here.
Strange that, https://data.buienradar.nl/2.0/feed/json indicate for every station ID a lat/lon of 0/0,
while https://data.buienradar.nl/1.0/feed/xml shows the correct lat/lon co-ordinates.
Wouldn't it be an idea to use this as a kind of back-up URL? In case the first one fails.
Same here.
- McMelloW
The first is a json feed, while the second is an XML feed.FireWizard wrote: ↑Monday 08 June 2020 16:28 Hi,
Same here.
Greetings McMelloW
- McMelloW
At 16:43 I saw a new update of the data. The coordinates for the stations are filled in again.
Perhaps it is a coincident, but it was 5 minutes after a posting on the Facebook page of BuienRadar
Greetings McMelloW
- waaren
I agree that is for the bigger part a serverside issue but I just checked this and at least for station 6344 (have only tested a few), buienradar returns stationid for both URL's (so for both all chars lowercase)
that 's probably because it just started working again (i see no more errors as of around 1650). long/lat is now also present again…
- waaren
- FireWizard
Is it working again? I doubt.
The last "Invalid data received......." was at 16:32, but since then every 5 minutes "Problem Connecting to Buienradar! (Check your Internet Connection!)"2020-06-08 16:32:30.448 Error: BuienRadar: Invalid data received (timestamp or staionid missing) or no data returned!
2020-06-08 16:32:35.482 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 16:37:40.374 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 16:42:45.864 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 16:47:50.746 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 16:52:56.276 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 16:58:01.206 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 17:03:06.818 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 17:08:11.891 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
There might be an opportunity to make the code more robust. Does someone know why these checks are in the code at GetMeterDetails() ?
to me it looks like they have no added value. Apparently these values are not always there in the json, and then the sensors will not be updated...
if (root["timestamp"].empty() == true || root["stationid"].empty() == true)
Log(LOG_ERROR, "Invalid data received (timestamp or staionid missing) or no data returned!");
return;
if (root["temperature"].empty() == true)
Log(LOG_ERROR, "Invalid data received (temperature missing) or no data returned!");
return;
int stationID = root["stationid"].asInt();
if (stationID != m_iStationID)
Log(LOG_ERROR, "Invalid data received (invalid stationid %d / %d ) or no data returned!", stationID, m_iStationID);
return;
- waaren
Works for me without any messages (station 6344). Also URL replies are normal again.
Could your issue be related to 1 particular station?
on my side it is. although a bit unstable. At 1655 i got a new errorFireWizard wrote: ↑Monday 08 June 2020 17:11 Hi,
2020-06-08 16:55:38.581 Error: BuienRadar: Problem Connecting to Buienradar! (Check your Internet Connection!)
2020-06-08 17:00:32.624 (Buienradar) Temp + Humidity (Buienradar TempHum)
2020-06-08 17:00:32.637 (Buienradar) Temp (Buienradar Grond Temperatuur (10 cm))
2020-06-08 17:00:32.647 (Buienradar) Temp (Buienradar Feel Temperature)
2020-06-08 17:00:32.657 (Buienradar) Wind (Buienradar Wind)
2020-06-08 17:00:32.667 (Buienradar) General/Custom Sensor (Buienradar Sun Power)
2020-06-08 17:00:32.691 (Buienradar) Rain (Buienradar Regen)
2020-06-08 17:00:33.020 (Buienradar) General/Custom Sensor (Tijd tot volgende bui)
2020-06-08 17:00:33.040 (Buienradar) General/Custom Sensor (Duur volgende bui)
2020-06-08 17:00:33.052 (Buienradar) General/Custom Sensor (Volgende bui intensiteit)
2020-06-08 17:00:33.063 (Buienradar) General/Custom Sensor (Next Rainshower Max Rainrate)
2020-06-08 17:00:33.073 (Buienradar) General/Percentage (Buienradar Rain Intensity)
2020-06-08 17:00:33.095 (Buienradar) General/Custom Sensor (Buienradar Rainfall next Hour)
2020-06-08 17:05:33.409 (Buienradar) General/Custom Sensor (Tijd tot volgende bui)
2020-06-08 17:05:33.418 (Buienradar) General/Custom Sensor (Duur volgende bui)
2020-06-08 17:05:33.426 (Buienradar) General/Custom Sensor (Volgende bui intensiteit)
2020-06-08 17:05:33.435 (Buienradar) General/Custom Sensor (Next Rainshower Max Rainrate)
2020-06-08 17:05:33.450 (Buienradar) General/Percentage (Buienradar Rain Intensity)
2020-06-08 17:05:33.465 (Buienradar) General/Custom Sensor (Buienradar Rainfall next Hour)
2020-06-08 17:10:33.834 (Buienradar) Temp + Humidity (Buienradar TempHum)
2020-06-08 17:10:33.845 (Buienradar) Temp (Buienradar Grond Temperatuur (10 cm))
2020-06-08 17:10:33.856 (Buienradar) Temp (Buienradar Feel Temperature)
2020-06-08 17:10:33.867 (Buienradar) Wind (Buienradar Wind)
2020-06-08 17:10:33.877 (Buienradar) General/Custom Sensor (Buienradar Sun Power)
2020-06-08 17:10:33.891 (Buienradar) Rain (Buienradar Regen)
2020-06-08 17:10:34.171 (Buienradar) General/Custom Sensor (Tijd tot volgende bui)
2020-06-08 17:10:34.184 (Buienradar) General/Custom Sensor (Duur volgende bui)
2020-06-08 17:10:34.193 (Buienradar) General/Custom Sensor (Volgende bui intensiteit)
2020-06-08 17:10:34.202 (Buienradar) General/Custom Sensor (Next Rainshower Max Rainrate)
2020-06-08 17:10:34.211 (Buienradar) General/Percentage (Buienradar Rain Intensity)
2020-06-08 17:10:34.220 (Buienradar) General/Custom Sensor (Buienradar Rainfall next Hour)
2020-06-08 17:15:34.547 (Buienradar) General/Custom Sensor (Tijd tot volgende bui)
2020-06-08 17:15:34.559 (Buienradar) General/Custom Sensor (Duur volgende bui)
2020-06-08 17:15:34.568 (Buienradar) General/Custom Sensor (Volgende bui intensiteit)
2020-06-08 17:15:34.577 (Buienradar) General/Custom Sensor (Next Rainshower Max Rainrate)
2020-06-08 17:15:34.586 (Buienradar) General/Percentage (Buienradar Rain Intensity)
2020-06-08 17:15:34.597 (Buienradar) General/Custom Sensor (Buienradar Rainfall next Hour)
I am seeing similar Problem Connecting to BuienRadar messages. I must also say that my sensors have been updated. The last change is 5 seconds before an error in the log. The sensors seem to be updated every 10 minutes while the error is there every 5 minutes.
- McMelloW
No errors at this side, getting updates every 10 mins.
Greetings McMelloW
- FireWizard
@waaren
You wrote:
So let us wait for at least another hour.
You wrote:
I changed my station for your station 6344, wherever that may beCould your issue be related to 1 particular station?
- waaren
$id": "36",
"stationid": 6344,
"stationname": "Meetstation Rotterdam",
"lat": 51.95,
"lon": 4.45,
"regio": "Rotterdam",
"timestamp": "2020-06-08T18:30:00",
"weatherdescription": "Zwaar bewolkt",
"iconurl": "https://www.buienradar.nl/resources/images/icons/weather/30x30/c.png",
"graphUrl": "https://www.buienradar.nl/nederland/weerbericht/weergrafieken/c",
"winddirection": "NNW",
"airpressure": 1016.4,
"temperature": 14,
"groundtemperature": 14.6,
"feeltemperature": 12.4,
"visibility": 28800,
"windgusts": 7.9,
"windspeed": 5.6,
"windspeedBft": 4,
"humidity": 81,
"precipitation": 0,
"sunpower": 160,
"rainFallLast24Hour": 2.9,
"rainFallLastHour": 0,
"winddirectiondegrees": 336
