HomeWizard and Intertechno ITL-500 for rollershutter
Posted: Saturday 06 June 2020 21:27
by TheExpert
Hello all,
I'm using Domoticz with the HomeWizard plugin and this works really great. You even don't need to create commands to get the status of all switches and sensors of the HomeWizard items automatically. This works by default.
The only thing is that I have 2 Intertechno ITL-500 devices connected to the HomeWizard for rollershutter. On HomeWizard the UP and DOWN commands work as they should. But with Domoticz the commands are reversed: UP is DOWN and DOWN is UP. But I can't change the options of these items. It doesn't work to set new commands for the ON and OFF options.
With the other SOMFY based rollershutters there's no issue. They work as they should.
Is the only way to set new virtual switches for the Intertechno items? But will I also get the status of these items automatically when using virtual switches on Domoticz?
Thank you.
Re: HomeWizard and Intertechno ITL-500 for rollershutter
Posted: Saturday 06 June 2020 23:33
by waaren
TheExpert wrote: Saturday 06 June 2020 21:27 Is the only way to set new virtual switches for the Intertechno items? But will I also get the status of these items automatically when using virtual switches on Domoticz?
Can't you change the device type in the edit window of the device?
(Click the edit button on the device on the switch tab)
Posted: Sunday 02 May 2021 14:50
by TheExpert
Sorry for my late answer. I didn't get a notification about your answer.
Your hint was very helpful. I changed the switch type to "Blind Inverted". This is working very good :D.
