Quick question: are there (noticeable) performance differences between Blockly, LUA, dZEvents or any other of the scripting languages within Domoticz?
And then I mean: either performance in running the script itself, but also hindering system performance. So, is a Blockly script heavier on the system than for example LUA?
Performance differences
- waaren
Re: Performance differences
Under the hood Blockly, Lua and dzVents are all using the same Lua engine in domoticz so from that perspective you will not see a difference.
However.. (from the dzvents wiki)
So if you have many device and timer triggered scripts and you are already reaching the limits of your system you might see a difference.If (on slower machines) events get queued up in Domoticz, they will be sent to dzVents in one-package. This makes event processing significantly faster.
Thanks! How do I know if I am reaching the limits of my system?
I think I am reaching the limits as it is an Atom N450 with 2GB of RAM.... which is not a lot!
- jvdz
- Domoticz version: 4.107
You'll notice it when the events start taking longer to complete as they are run in a single thread sequentially.
I am not a user of dZEvents as I've already scripted everything in LUA files, but can confirm like @waaren stated that it is way faster to work with one devices and timescript event script and have those master-scripts do the processing for all time/device events.
Jos
Jos
I use 70+ scripts in dzVents and 10+ scripts in bash by cron.
On the hour almost everything is running, and all scripts ends within 1 second on a Pi 3B+ My average CPU use is approx. 5%
Of course after a few seconds comes the response from different httpResponse-events
Well, sounds like there is not going to be an issue. I'll just have to pick the way of coding that suits me best. Thanks all!
