BUG: dzvents: customEvent.data table value is returned as string
Posted: Monday 01 June 2020 22:27
Version: 2020.2 (build 12067)
Build Hash: 0fc3c7b70
Compile Date: 2020-05-17 13:15:45
dzVents Version: 3.0.5
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
https://www.domoticz.com/wiki/DzVents:_ ... nd_methods
If I put a table variable in the 2nd variable [extra data] of emitEvent(name,[extra data]), that variable is of type string when the event triggers. In below code, the values of object.data.idx, object.data.bState and object.data.lastUpdate all equal nil. This is because object.data is of type "string", instead of type "table" that it was when it was emitted.
When the trigger fires, the value of data is no longer of type table. It is now "{"bState":true,"idx":552,"lastUpdate":{"addDays":"Function","addHours":"Function","addMinutes":"Function","addSeconds":"Function","compare":"Function","current":{"day":1,"hour":22,"isdst":true,"min":21,"month":6,"sec":28,"wday":2,"yday":153,"year":2020},"dDate":1591042886,"day":1,"dayAbbrOfWeek":"mon","dayName":"Monday","daysAgo":0,"getISO":"Function","hour":22,"hoursAgo":0,"isToday":true,"isUTC":false,"isdst":true,"makeTime":"Function","matchesRule":"Function","milliSeconds":0,"milliseconds":0,"millisecondsAgo":2995,"min":21,"minutes":21,"minutesAgo":0,"minutesSinceMidnight":1341,"month":6,"monthAbbrName":"jun","monthName":"June","msAgo":2995,"raw":"2020-06-01 22:21:26","rawDate":"2020-06-01","rawDateTime":"2020-06-01 22:21:26","rawTime":"22:21:26","ruleIsAfterCivilTwilightEnd":"Function","ruleIsAfterCivilTwilightStart":"Function","ruleIsAfterSunrise":"Function","ruleIsAfterSunset":"Function","ruleIsAtCivilDayTime":"Function","ruleIsAtCivilNightTime":"Function","ruleIsAtCivilTwilightEnd":"Function","ruleIsAtCivilTwilightStart":"Function","ruleIsAtDayTime":"Function","ruleIsAtNight":"Function","ruleIsAtSunrise":"Function","ruleIsAtSunset":"Function","ruleIsBeforeCivilTwilightEnd":"Function","ruleIsBeforeCivilTwilightStart":"Function","ruleIsBeforeSunrise":"Function","ruleIsBeforeSunset":"Function","ruleIsInWeek":"Function","ruleIsOnDate":"Function","ruleIsOnDay":"Function","ruleMatchesBetweenRange":"Function","ruleMatchesHourSpecification":"Function","ruleMatchesMinuteSpecification":"Function","ruleMatchesTime":"Function","ruleMatchesTimeRange":"Function","sec":26,"seconds":26,"secondsAgo":2,"secondsSinceMidnight":80486,"time":"22:21","utils":{"DZVERSION":"3.0.5","LOG_DEBUG":4,"LOG_ERROR":1,"LOG_FORCE":0.5,"LOG_INFO":3,"LOG_MODULE_EXEC_INFO":2,"cameraExists":"Function","centerPad":"Function","deviceExists":"Function","dumpSelection":"Function","dumpTable":"Function","fileExists":"Function","fromBase64":"Function","fromJSON":"Function","fromXML":"Function","groupExists":"Function","hsbToRGB":"Function","inTable":"Function","isJSON":"Function","isXML":"Function","leadingZeros":"Function","leftPad":"Function","log":"Function","numDecimals":"Function","osExecute":"Function","print":"Function","rgbToHSB":"Function","rightPad":"Function","round":"Function","sceneExists":"Function","setLogMarker":"Function","stringSplit":"Function","stringToSeconds":"Function","toBase64":"Function","toCelsius":"Function","toJSON":"Function","toXML":"Function","urlDecode":"Function","urlEncode":"Function","variableExists":"Function"},"wday":2,"week":23,"yday":153,"year":2020}}"
I do see that this is a json, so I will be able to convert it back into a table. But the point is: I shouldn't have to. I assigned a table, so I expect to receive a table.
Here's the code I used to verify this behavior:
domoticz.emitEvent('myTestEvent', { idx = object.idx, bState = object.bState, lastUpdate = object.lastUpdate } )I do see that this is a json, so I will be able to convert it back into a table. But the point is: I shouldn't have to. I assigned a table, so I expect to receive a table.
devices = {
"myTest"
customEvents = {
"myTestEvent*"
execute = function(domoticz, object, triggerInfo)
if object.isDevice then
domoticz.log('Device ' .. object.name .. ': state ' ..tostring(object.bState).. '.', domoticz.LOG_FORCE)
if object.bState == true then
domoticz.emitEvent('myTestEvent', { idx = object.idx, bState = object.bState, lastUpdate = object.lastUpdate } ).afterSec(15)
-- domoticz.emitEvent( "myTestEvent" ).afterSec(30)
elseif object.isCustomEvent then
domoticz.log('CustomEvent, ' .. type(object) .. '.', domoticz.LOG_ERROR)
domoticz.log('CustomEvent, "' .. object.data .. '".', domoticz.LOG_ERROR)
--domoticz.utils.dumpTable(object)
domoticz.log('CustomEvent, ' .. type(object.data) .. ', idx = '.. tostring(object.data.idx) .. ', bState = ' ..tostring( object.data.bState) .. '.', domoticz.LOG_ERROR)
if object.data == nil then
domoticz.log('CustomEvent, data is nil.', domoticz.LOG_ERROR)
elseif object.data.idx == nil then
domoticz.log('CustomEvent, data.idx is nil.', domoticz.LOG_ERROR)
local dev = domoticz.devices(object.data.idx)
if dev == nil then
domoticz.log('CustomEvent, device ' .. tostring(domoticz.data.idx) .. ' not found.', domoticz.LOG_ERROR)
if dev.bState == object.data.bState and dev.lastUpdate == object.data.lastUpdate then
domoticz.log('CustomEvent, device ' .. dev.name .. ' is still on.', domoticz.LOG_FORCE)
domoticz.log('CustomEvent, device ' .. dev.name .. ' is off.', domoticz.LOG_FORCE)
domoticz.log( "unexpected trigger type.", domoticz.LOG_FORCE)
