BUG: dzvents: customEvent.data table value is returned as string  [SOLVED]
rrozema
Post by rrozema »
Version: 2020.2 (build 12067)
Build Hash: 0fc3c7b70
Compile Date: 2020-05-17 13:15:45
dzVents Version: 3.0.5
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
https://www.domoticz.com/wiki/DzVents:_ ... nd_methods
If I put a table variable in the 2nd variable [extra data] of emitEvent(name,[extra data]), that variable is of type string when the event triggers. In below code, the values of object.data.idx, object.data.bState and object.data.lastUpdate all equal nil. This is because object.data is of type "string", instead of type "table" that it was when it was emitted.
domoticz.emitEvent('myTestEvent', { idx = object.idx, bState = object.bState, lastUpdate = object.lastUpdate } )
When the trigger fires, the value of data is no longer of type table. It is now "{"bState":true,"idx":552,"lastUpdate":{"addDays":"Function","addHours":"Function","addMinutes":"Function","addSeconds":"Function","compare":"Function","current":{"day":1,"hour":22,"isdst":true,"min":21,"month":6,"sec":28,"wday":2,"yday":153,"year":2020},"dDate":1591042886,"day":1,"dayAbbrOfWeek":"mon","dayName":"Monday","daysAgo":0,"getISO":"Function","hour":22,"hoursAgo":0,"isToday":true,"isUTC":false,"isdst":true,"makeTime":"Function","matchesRule":"Function","milliSeconds":0,"milliseconds":0,"millisecondsAgo":2995,"min":21,"minutes":21,"minutesAgo":0,"minutesSinceMidnight":1341,"month":6,"monthAbbrName":"jun","monthName":"June","msAgo":2995,"raw":"2020-06-01 22:21:26","rawDate":"2020-06-01","rawDateTime":"2020-06-01 22:21:26","rawTime":"22:21:26","ruleIsAfterCivilTwilightEnd":"Function","ruleIsAfterCivilTwilightStart":"Function","ruleIsAfterSunrise":"Function","ruleIsAfterSunset":"Function","ruleIsAtCivilDayTime":"Function","ruleIsAtCivilNightTime":"Function","ruleIsAtCivilTwilightEnd":"Function","ruleIsAtCivilTwilightStart":"Function","ruleIsAtDayTime":"Function","ruleIsAtNight":"Function","ruleIsAtSunrise":"Function","ruleIsAtSunset":"Function","ruleIsBeforeCivilTwilightEnd":"Function","ruleIsBeforeCivilTwilightStart":"Function","ruleIsBeforeSunrise":"Function","ruleIsBeforeSunset":"Function","ruleIsInWeek":"Function","ruleIsOnDate":"Function","ruleIsOnDay":"Function","ruleMatchesBetweenRange":"Function","ruleMatchesHourSpecification":"Function","ruleMatchesMinuteSpecification":"Function","ruleMatchesTime":"Function","ruleMatchesTimeRange":"Function","sec":26,"seconds":26,"secondsAgo":2,"secondsSinceMidnight":80486,"time":"22:21","utils":{"DZVERSION":"3.0.5","LOG_DEBUG":4,"LOG_ERROR":1,"LOG_FORCE":0.5,"LOG_INFO":3,"LOG_MODULE_EXEC_INFO":2,"cameraExists":"Function","centerPad":"Function","deviceExists":"Function","dumpSelection":"Function","dumpTable":"Function","fileExists":"Function","fromBase64":"Function","fromJSON":"Function","fromXML":"Function","groupExists":"Function","hsbToRGB":"Function","inTable":"Function","isJSON":"Function","isXML":"Function","leadingZeros":"Function","leftPad":"Function","log":"Function","numDecimals":"Function","osExecute":"Function","print":"Function","rgbToHSB":"Function","rightPad":"Function","round":"Function","sceneExists":"Function","setLogMarker":"Function","stringSplit":"Function","stringToSeconds":"Function","toBase64":"Function","toCelsius":"Function","toJSON":"Function","toXML":"Function","urlDecode":"Function","urlEncode":"Function","variableExists":"Function"},"wday":2,"week":23,"yday":153,"year":2020}}"
I do see that this is a json, so I will be able to convert it back into a table. But the point is: I shouldn't have to. I assigned a table, so I expect to receive a table.
Here's the code I used to verify this behavior:
		devices = {
		    "myTest"
		customEvents = {
			"myTestEvent*"
    execute = function(domoticz, object, triggerInfo)
        if object.isDevice then
            domoticz.log('Device ' .. object.name .. ': state ' ..tostring(object.bState).. '.', domoticz.LOG_FORCE)
            if object.bState == true then
                domoticz.emitEvent('myTestEvent', { idx = object.idx, bState = object.bState, lastUpdate = object.lastUpdate } ).afterSec(15)
--                domoticz.emitEvent( "myTestEvent" ).afterSec(30)
        elseif object.isCustomEvent then
            domoticz.log('CustomEvent, ' .. type(object) .. '.', domoticz.LOG_ERROR)
            domoticz.log('CustomEvent, "' .. object.data .. '".', domoticz.LOG_ERROR)
            --domoticz.utils.dumpTable(object)
            domoticz.log('CustomEvent, ' .. type(object.data) .. ', idx = '.. tostring(object.data.idx) .. ', bState = ' ..tostring( object.data.bState) .. '.', domoticz.LOG_ERROR)
            if object.data == nil then
                domoticz.log('CustomEvent, data is nil.', domoticz.LOG_ERROR)
            elseif object.data.idx == nil then
                domoticz.log('CustomEvent, data.idx is nil.', domoticz.LOG_ERROR)
                local dev = domoticz.devices(object.data.idx)
                if dev == nil then
                    domoticz.log('CustomEvent, device ' .. tostring(domoticz.data.idx) .. ' not found.', domoticz.LOG_ERROR)
                    if dev.bState == object.data.bState and dev.lastUpdate == object.data.lastUpdate then
                        domoticz.log('CustomEvent, device ' .. dev.name .. ' is still on.', domoticz.LOG_FORCE)
                        domoticz.log('CustomEvent, device ' .. dev.name .. ' is off.', domoticz.LOG_FORCE)
            domoticz.log( "unexpected trigger type.", domoticz.LOG_FORCE)
Re: BUG: dzvents: customEvent.data table value is returned as string
rrozema wrote: Monday 01 June 2020 22:27 I do see that this is a json, so I will be able to convert it back into a table. But the point is: I shouldn't have to. I assigned a table, so I expect to receive a table.
From the wiki:
json. Table. 3.0.3 When the customEvent data is a valid json string, the response data is automatically converted to a Lua table for quick and easy access.
check below (tested on dzVents 3.0.8):
		devices = {
		    "customEventTrigger"
		customEvents = {
			"myTestEvent*"
            domoticz.log('CustomEvent, ' .. type(object) .. '.', domoticz.LOG_FORCE)
            domoticz.log('CustomEvent.json, ' .. type(object.json) .. ', idx = '.. tostring(object.json.idx) .. ', bState = ' ..tostring( object.json.bState) .. '.', domoticz.LOG_FORCE)
            if object.json == nil then
                domoticz.log('CustomEvent, json is nil.', domoticz.LOG_FORCE)
            elseif object.json.idx == nil then
                domoticz.log('CustomEvent, json.idx is nil.', domoticz.LOG_FORCE)
                local dev = domoticz.devices(object.json.idx)
                if dev == nil then
                    domoticz.log('CustomEvent, device ' .. tostring(domoticz.json.idx) .. ' not found.', domoticz.LOG_FORCE)
                    if dev.bState == object.json.bState and dev.lastUpdate == object.json.lastUpdate then
log:
2020-06-02 01:11:14.312  Status: dzVents: Info: Handling events for: "customEventTrigger", value: "On"
2020-06-02 01:11:14.312  Status: dzVents: Info: ------ Start internal script: 20200602 dz customEvent json: Device: "customEventTrigger (Virtual)", Index: 222
2020-06-02 01:11:14.313  Status: dzVents: !Info: Device customEventTrigger: state true.
2020-06-02 01:11:14.314  Status: dzVents: Info: ------ Finished 20200602 dz customEvent json
2020-06-02 01:11:29.377  Status: dzVents: Info: Handling Domoticz custom event for: "myTestEvent"
2020-06-02 01:11:29.377  Status: dzVents: Info: ------ Start internal script: 20200602 dz customEvent json: Custom event: "myTestEvent"
2020-06-02 01:11:29.379  Status: dzVents: !Info: CustomEvent, table.
2020-06-02 01:11:29.379  Status: dzVents: !Info: CustomEvent.json, table, idx = 222, bState = true.
2020-06-02 01:11:29.385  Status: dzVents: !Info: CustomEvent, device customEventTrigger is off.
2020-06-02 01:11:29.385  Status: dzVents: Info: ------ Finished 20200602 dz customEvent json
rrozema
Post by rrozema »
waaren wrote: Tuesday 02 June 2020 1:15 From the wiki:
Thanks for the sample code, that should work great. Much appreciated!
The quoted piece of wiki however doesn't cover my problem area: the [extra data] I put in isn't a valid json string, it is a table.
I suggest to add a mention of the table to json conversion behavior within the emitEvent() function:
emitEvent(name,[extra data ]):Function. 3.0.0 Have Domoticz ‘call’ a customEvent. If you just pass a name then Domoticz will execute the script(s) that subscribed to the named customEvent after your script has finished. You can optionally pass extra information as a string or table. If you pass in a table, that table will be automatically converted into a json string. Supports command options.
And add another bit of information in the 'Sections of the script' part to clarify that the data can be retrieved from the json or the xml property as a LUA table, while the data property holds the json or xml string:
  • data: Raw customEvent data.
  • isJSON: Boolean.3.0.3 true when the customEvent data is a valid json string.
  • isXML: Boolean.3.0.3 true when the customEvent data is a valid xml string.
  • json. Table.3.0.3 If isJSON is true, json will hold the extra data passed in, converted into a LUA table for quick and easy access. nil if isJSON is not true.
  • trigger, customEvent: String.3.0.3 The string that triggered this customEvent instance. This is useful if you have a script that is triggered by multiple different customEvent strings.
  • xml. Table. 3.0.3 If isXML is true, xml will hold the extra data passed in, converted into a Lua table for quick and easy access. nill if isXML is not true.
Re: BUG: dzvents: customEvent.data table value is returned as string  [SOLVED]
rrozema wrote: Tuesday 02 June 2020 8:35 I suggest to add a mention of the table to json conversion behavior within the emitEvent() function:
Will do.
