Strange behaviour lastupdate.secondsAgo  [Solved]
acaonweb
Post by acaonweb »
before 2020.1 i was able to calculate seconds between two updates of a dummy switch.
the code is like that
		devices = {'update'},
	data = {},
	logging = {
	    level = domoticz.LOG_DEBUG,
	    marker = "update: "
	execute = function(dz, device, tginfo)
	   local update=dz.devices('update')
	   dz.log(update.lastUpdate.secondsAgo)
switching the state of a dummy switch, i can have seconds using that code, and it was working
Now log tell me 0 seconds...
2020-05-29 16:48:07.010 Status: dzVents: Info: Handling events for: "update", value: "Off"
2020-05-29 16:48:07.010 Status: dzVents: Info: update: : ------ Start internal script: test: Device: "update (Dummy)", Index: 187
2020-05-29 16:48:07.011 Status: dzVents: Info: update: : 0
2020-05-29 16:48:07.012 Status: dzVents: Info: update: : ------ Finished test
What's changed? What is my mistake?
Thanx in advance
Re: Strange behaviour lastupdate.secondsAgo
acaonweb wrote: Friday 29 May 2020 16:50 before 2020.1 i was able to calculate seconds between two updates of a dummy switch.
What is your domoticz / dzVents version ?
between build 11886 and 12002 the lastUpdate value was not correctly send to dzVents. also see issue 4112
acaonweb
Post by acaonweb »
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Re: Strange behaviour lastupdate.secondsAgo  [Solved]
acaonweb wrote: Saturday 30 May 2020 7:39 Version: 2020.2, Build Hash: b63341bc0
This version indeed suffers from that issue. So either update to Beta or wait for the next release
(Please don't ask when the next release will come as no one knows)
acaonweb
Post by acaonweb »
Workaround?
acaonweb wrote: Sunday 31 May 2020 18:42Workaround?
Install latest Beta
acaonweb
Post by acaonweb »
Well, without any kind of polemic, i think a big bug like that (a command that stop to works) needs a quick bug fix, and potentially beta can resolve this bug but introduce many others...
I’m worried about that, I’ll think on.
