I've recently bought the Pi4, on which I want to run domoticz
However, on my Pi3, everything is running fine, including Atag One, which is quite hard to get working properly
So, I was thinking: can I make a clone of my sdcard, and move on from there?
Or better yet: just put the sdcard of the pi3 in the pi4? (probably add SSH file to enable ssh once again)
I can't overlook the consequences for Domoticz (besides from altering some scripts where the IP of my device is hard coded)
Perhaps anyone has experience doing this?
tnx
Move SD card to new pi
- Rolandet
- Domoticz version: 2021.1
Custodes Septentrionum
Bigted
- Domoticz version: 2020.1
Re: Move SD card to new pi
Which version of Raspbian is running on your Pi 3 as a Pi 4 needs Buster
If it has Buster on it then it should be able to moved to the Pi 4
If it is older than Buster I'd make a backup copy of the SD card and upgrade the backup card to Buster while running on the Pi 3. Don't do anything without a working copy of your SD card and only use the backup card when upgrading or swapping
As for the IP address, I'd make sure that the Pi 4 kept the IP address of the old Pi
- Rolandet
The pi3 has Buster running too (upgraded a little while ago)Bigted wrote: Thursday 28 May 2020 22:25 Which version of Raspbian is running on your Pi 3 as a Pi 4 needs Buster
So, I'll make a backup copy of the SD, and then try to run it on the Pi4
tnx
(ill update the result)
