Unexpected result with nested if statement  [Solved]
Ragdag
Post by Ragdag »
I have the following piece of code.
        if (item.isDevice) and ((User1Thuis.state == 'Off') and (User2Thuis.state == 'Off') and VakantieSchema.state == 'Off') then
            dz.log('User1 and User2 not at home, turning on holiday lighting schedule', dz.LOG_DEBUG)
            pushover(PushoverUsers.User1, PushoverApps.Huis, 'Vakantie Verlichting', 'User1 and User2 not at home. \nTurning on holiday lighting schedule', 0, 'none' )
            VakantieSchema.switchOn()
        elseif (item.isDevice) and ((User1Thuis.state == 'On') or (User2Thuis.state == 'On') and VakantieSchema.state == 'On') then
            VakantieSchema.switchOff()
            dz.log('User1 and User2 at home, turning off holiday lighting schedule', dz.LOG_DEBUG)
            if (User1Thuis.state == 'On') and (User2Thuis.state == 'Off') then
                pushover(PushoverUsers.User1, PushoverApps.Huis, 'Vakantie Verlichting', 'User1 is home. \nTurning off holiday lighting schedule', 0, 'none' )
            elseif (User2Thuis == 'On') and (User1Thuis.state == 'Off') then
                pushover(PushoverUsers.User1, PushoverApps.Huis, 'Vakantie Verlichting', 'User2 is home. \nTurning off holiday lighting schedule', 0, 'none' )
            elseif (User1Thuis.state == 'On') and (User2Thuis.state == 'On') then
                pushover(PushoverUsers.User1, PushoverApps.Huis, 'Vakantie Verlichting', 'User1 and User2 are home. \nTurning off holiday lighting schedule', 0, 'none' )
I would expect that the nested if block:
"if (User1Thuis.state == 'On') and (User2Thuis.state == 'Off') then"
would only be executed if the main
"elseif (item.isDevice) and ((User1Thuis.state == 'On') or (User2Thuis.state == 'On') and VakantieSchema.state == 'On') then" block is true.
That is not the case and it will trigger the pushover notification.\
Am I missing something?
Re: Unexpected result with nested if statement
Ragdag wrote: Tuesday 26 May 2020 8:37 ...
Hard to tell without seeing the log. Can you use this in your script and share the relevant log lines? It will show you and us some potential useful information about the flow through the code.
        dz.log('----------- 1 --------', dz.LOG_DEBUG)
            dz.log('----------- 2 --------', dz.LOG_DEBUG)
            dz.log('----------- 3 --------', dz.LOG_DEBUG)
                dz.log('----------- 4 --------', dz.LOG_DEBUG)
                dz.log('----------- 5 --------', dz.LOG_DEBUG)
                dz.log('----------- 6 --------', dz.LOG_DEBUG)
Ragdag
Re: Unexpected result with nested if statement  [Solved]
Post by Ragdag »
Never mind, I think I found it the brackets are not correct :oops:
In the elseif the 2 OR statements should be grouped and currently it is the OR and the AND that is grouped.
